Ball joints and roll centres
Your points are well taken. What I meant was that changing the geometry on the Camaro will produce the same geometric changes as on the Corvette. Now, what affect that will have on the car is obviously going to be different. However, with any of these suspension programs, you could use the Camaro dimensions and the Vette COG height and overall dimensions to get an IDEA of how changes will affect the car. This would be a way to experiment if you didn't have the Vette geometry. Mainly, I think it's a good idea for someone to see what the changes do to all the other suspension characteristics.
Ken
http://www.trucksim.com/carsim/
I am still willing to make CD's and send them, but if someone had an idea for posting these programs, let me know. For those of you who have already requested them, I made some last night, and the will be hitting the mail very soon.
Also, here is a link to the sSNAP site. This is a consulting firm based here in Michigan. It looks like they have updated the program significantly. The student version I have is not as refined with as many windows, but it does have the 3D viewer.
http://www.suspensionsim.com/suspensionsim/index.htm
Ken
I checked bump steer at least 2 inches down and 4 inches up and the change up was inches and almost no change down.
I hope to work on this more this summer. Along with the stronger springs I hope not to move through 4 inches rise on launch.
Thank you for the offer on the pump steer but the shipping would get rediculous and Roger would loan me his.
I too wonder about the Steeroid mounting. If everything is not in alignment toe out is a good possibility. If a line drawn through the out tie rods ends does not pass through the center of the rack toe out happens whenever this becomes a straight line.
Thanks Pete.
I quickly ran three versions of the Camaro setup so I could see the change to roll center hieght. The results are below in mm.
Stock Camaro is 31.77
Camaro with Gulstrand mod (redrilling a-arm mounting holes) is 81.9
Raising upper ball joint one inch is 86.68
This gives you an idea of what the adjustable ball joint will do. Until we get the Vette geometry, you can use this as a rough estimate.
Ken
I did not pay any attention to the stock configuration so I can't comment on it...
my measurement of the lower a arm seems to be ~17 inches from BJ center to pivot point center in rear of arm...and my tie rods are 20 and 22 nches long...due to my moving rack toward driver's side in a vain attempt to clear the headers i HAD on the car....wound up changing them anyway....
but thing is here....I think having the tie rods flat level across the car, would make the wheels tow out on the upswing and the downswing....I thought of that, and sort of split the differance.....Jim Shea thought a longer tie rod was a good thing, as the swing arc is reduced, I sorta agree with him...
so my suspension on the downswing, less loading, jounce, will then make the tie rods effective longer, and if going far enough, make them shorter again...
on the bounce, compression upswing...they only get shorter making more tow out....
I would think raising the tie rod centers would help my situation a LOT....
I sorta wonder if I"m not getting way too much tire wear on account of that being too low....
but then again,....Norval, you commented on lowering your stock tie rods/drag link....
so what gives guys????
GENE
When I pulled the car down towards the floor and I have the ability to totally collapse the suspension the high inner tie rods moved down and very little change to the toe.
So I reasoned that my inner and outer tie rods should be about the same height. Since my inners were high I had to lower both of them. I did this with a lower pitman arm and extended drag link.
As for mounting the rack I was talking about mounting it in line with the outer tie rods front and back, not up and down.
Mounting the rack behind the center line between the 2 outer tie rods will result in unwanted toe out at a certain degreee of turning.
Mounting the rack 2 inches behind this centerline results in about .500 inches of toe out at a certain turn radius and yet when pointed straight ahead toe is back to normal.
Mounting the rack up and down from this line is another problem.
Some one said a little knowledge is dangerous. I am Dangerous. I have little knowledge. Just enought to get me into trouble.
I am just reading this suspension book and there was a warning about mounting the rack and I am just repeating my interpretation of what they said. Someone else reading it might interpretate something else.
so when accelarating, the tires tend to go to a further toe out situation...
but if the tie rods were flat at rest...the tires would allways be forced into a toe out situation regardless of braking OR accelerating....
I looked at that and thought about it a bit....and decided to go with this set up....not entirely sure i'ts correct/best as possible...just that it SEEMED ok compromise to me....
anybody??? Pete???
GENE
anybody??? Pete???
GENE
Gene, you are correct on most of your assumptions as far as where the tires will go. But you are assuming both wheels are doing the same thing so each cancels out the effects of the other. What happens when one wheel hits a rut in the road. Or when you enter a corner hard. On a hard left turn first the nose will drop down, causing a toe in situation, then weight in transfered to the right front tire causing it to drop farther, making the tire start to toe out, all while the left front tire is having weight transfered off of it causing it to rise and go to a toe out situation. This has to make the steering unpredictable as the wheels are not going in the direction the steering is tell them to go, causing a constant correction at the steering wheel.
I see you have larger wheels. Do you have enough room to move the steering arm on the spindle down to get the tie rods closer to the same plane as the lower a-frame? I know there is not much room to move them with 15" wheels but with larger wheels this may be an option.
By using a center take off rack on a car with unequal length a-frame you will never get the bump streer correct. You have to use a end take off rack to do that. But I do think with some work you can get it to an acceptable level.
Pete
Ken
I am sure Norval has taken these things into consideration to arrive at the mods he whats to do.
Pete
I tried with a friend down the road, but he is slammed with work....
please send me a email...
mrvette72@interstateweb.net
my largest concern is about anyting being radically rong with what I have done....I don't think so...BUT....a further understanding is allways helpful....
thanks muchly everyone....
GENE
I wish I had talked to Pete earlier. He has given me more to think about and of coarse lay under the car and try to visualize what he is telling us. Obviously he knows far more then us.
I can't do any of this now with the car on jack stands but this summer I will get back into looking to eliminate bump steer. It has bugged me for years.
The ultimate goal for my vette is to have it as close to a modern car in terms of performance and engineering as possible. The drivetrain is easy to take care of. The brakes are slightly more difficult but still not too hard. The suspension, however, is the most difficult item to remedy. Swapping the suspension from a C4 is much more of a task than dropping in an engine or building brackets for calipers. Naturally there were some engineering compromises made at the beginning that aren't as useful now with the improved tires and larger wheel sizes. Knowing what to change and WHY is an important thing to know for all of us that aren't satisfied with 30-50 year old technology in our cars.
-Jason
GENE
Gene:
I don't think you have done anything wrong as far as being unsafe. I think we just need to tweak it a little to make it better and get a better feed back to the steering wheel.
Bump steer is the last thing you want to adjust in front end geometry because changeing bump steer will not affect anything else but every thing else you do to the front suspension affects bump steer.
Once you get some measurements let me know.
Pete
so the looks of it with a string going from tie rod knuckle ends to opposite side is....and this IS strange...shows what trying to site something from not being under the car and definitive get me......
the ceter linkage...rack output is just about an inch low, and two inches to the rear compared to the knuckle position.....the ride height from the bottom of the upper A arm to the frame...there is no rubber snubber...is damn close to two inches...maybe 2.25 inches....
GENE
Try to get me the following measurements amd be as accurate as you can, to the 1/64" if possible.
The distance from:
The ground to the inner tie rod pivot.
The ground to the outer tie rod pivot
The ground to the inner lower a-frame pivot
The ground to the lowwer ball joint pivot
The length of the lower a-frame from inner pivot to ball joint pivot
The length of the tie rod from inner pivot to outer pivot
I know that some of the demension will be difficult to get accurately but try to get as close as you can.
With those dimensions I can plot the suspension movement out on a CAD program and tell us what you bump steer is with fairly close accuracy.
Pete
No can't do for a 64th..but for 1/4 or so...fine...
The distance from:
6.25...should swing center...I think..pretty close anyway...
7.5...again, swing center
Easy...bolt center...9.75 all 4 corners....
again...kinds hard to know exactly...but close to 9.5 inches...
Boath A arms are stock, and as such seem to measure 18" in front from bolt center to what seems like BJ centerline...at pivot point...
and same thing in rear is 17".....
OK rack is mounted off center by about one inch...attempted to clear original headers...failed...changed headers anyway..but brackets remained..at some point I wanted to just get the damn thing back on the road....so here is...
22 inches pass side....and 20 inches driver's side....
Thanks, Pete, I appreciate your help on this....
GENE
Pete
Pete
[Modified by Pete79L82, 4:28 PM 3/14/2003]
7.5...again, swing center yup...damn close...depends on what I interpret as the exact center of the ball joint, but fromm just looking at the casting and the center of the input shaft...and the lay of the thing... yup...7.5"
yup, the ball joint center is higher than the input of the tie rod ends...
it's the ONLY ball joint I ever seen that in fact if mounted 'upside down'...and the stem points to the ground...with the A arm ABOVE the spindle, and is making that center higher....
GENE
Gene: Am I not following this correct? Does this mean that the outer tie rod is lower than the lower ball joint? yup,,...by about 1.5 inches at minimum...
Pete
