Replacing brake pads
Old Mar 6, 2003 | 06:49 PM
Jvette73's Avatar
Jvette73
Default Replacing brake pads
Im gonna be replacing brake pads front and rear and turning the rotors in the near future. Ive had them apart before and its no big deal. However, When I pulled the pads last time the caliper pistons sprung out and I lost some fluid and had to re-bleed. Ive seen the clips available to hold the pistons in place while removing the pads. Ide rather find a method on my own to hold the pistons in and save the $ on the clips. Does anyone have a technique they can share that they have used in the pass which will help me perform this task without having to buy the clips?
Old Mar 6, 2003 | 07:37 PM
Touringpro's Avatar
Touringpro
Default Re: Replacing brake pads (Jvette73)
Sure. Just use a small block of wood between the pads and/or pistons to keep them in their sleeves.
Old Mar 6, 2003 | 08:04 PM
Rogue Wave's Avatar
Rogue Wave
CI 4-5-6-7-8 Veteran
St. Jude '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-16-'17
I've always spread the pads as far as I can before I remove them from the calipers. If you are careful you really don't need anything to keep them spread. (Just don't press the brake pedal :) )
I've never had a piston come out on me. Ya gotta be careful.
If you are concerned about a piston... a block of word or equivalent is a good thing. :thumbs:
Old Mar 7, 2003 | 03:50 AM
Jvette73's Avatar
Jvette73
Givin the fact that there springs behind the pistons my main concern was the lip seal comming out. I could tackle that too without much trouble anyhow. The calipers were all rebuilt by me not too long ago so I suppose the outer dust seal should help keep them in place as well. I just picked up PFC carbon metalic pads. They come with backing plates which my current pads do not have. Should I use the backing plates provided with the new pads? What advantages will they give me?
Old Mar 7, 2003 | 09:20 AM
LRPMAN's Avatar
LRPMAN
Have you tried that brake caliper clip form Ecklers I think. Saw it in a book and plan to find an get a set. :cheers:
Old Mar 7, 2003 | 09:34 AM
Ganey's Avatar
Ganey
... However, When I pulled the pads last time the caliper pistons sprung out and I lost some fluid and had to re-bleed. Ive seen the clips available to hold the pistons in place while removing the pads. ...
The pistons should not come out on their own.
Get the clips or make some! Have had the original one piece clip a long time.
The clips are the way to go- fast & easy pad changes!
:cool:
Old Mar 7, 2003 | 09:53 AM
gliot1's Avatar
gliot1
St. Jude Donor '12-'13
The clips are worth it. I'v also read to use a piece of styrofoam inbetween and as you slide the caliper down it will push right out.
Old Mar 7, 2003 | 10:07 AM
Ganey's Avatar
Ganey
Default Re: Replacing brake pads (gliot1)
See what you mean.
There is no reason to remove the caliper to change pads.
Old Mar 7, 2003 | 05:45 PM
jerryp58's Avatar
jerryp58
I didn't like having to push the pistons around the last time I removed/reinstalled the pads, so I bought the clips to have for the next time.
Hopefully, they'll work well.
To Replacing brake pads
