Oxygen Sensor
Old Mar 12, 2003 | 06:08 PM
Chris69's Avatar
Chris69
Default Re: Oxygen Sensor (Dalannex)
Check out this site for everything you wanted to know about oxygen sensor types... http://www.forparts.com/Bos02update2.htm :cheers:
Old Mar 12, 2003 | 07:42 PM
BSeery's Avatar
BSeery
From: Exiled to Richmond, VA - Finally sold my house in Murfreesboro, TN ?? Corner of "Bumf*&k and 'You've got a purdy mouth'."
CI 6-7-8 Veteran
CI-VIII Burnout Champ
St. Jude Donor '06-'10, '13
Here's an update for anybody thinking of going with a heated sensor. Bosch makes a universal, that comes with instructions as to what wire on the sensor is for what, zirconia element and all. I'm not sure what it has for connectors, mainly becasue I will more than likely have to change them to match my car. I am getting a 4 wire, but I imagine they make 3 wire too if you want to go that route. Makes it easier than trying to decipher what wire does what on a different sensor.
-Justin
got a part number on that ????
Old Mar 12, 2003 | 08:07 PM
PatsLs1vette's Avatar
PatsLs1vette
Default Re: Oxygen Sensor (BSeery)
i just got a 3 wire from advanced auto for mine $39.95if you want the part number ill go outside and get it its a bosch,it really helped out my motor alot.
its a part #13953 bosch
[Modified by patsnitrovette, 8:09 PM 3/12/2003]
Old Mar 12, 2003 | 08:17 PM
BSeery's Avatar
BSeery
CI 6-7-8 Veteran
Default Re: Oxygen Sensor (patsnitrovette)
thanks for the part number -- do you have a wiring schematic (what color wire does what) ?
Old Mar 12, 2003 | 08:46 PM
PatsLs1vette
youll have 3 wires 1 black wire goes to ecm then youll have 2 white wires one for 12 volt source other for ground doesnt matter which way.
[Modified by patsnitrovette, 8:47 PM 3/12/2003]
Old Mar 12, 2003 | 09:02 PM
Chris69's Avatar
Chris69
I wonder what the difference is in these sensors. That part number is for a Ford, I think. Maybe for cross-reference sakes they gave them different numbers but they're the same thing? :crazy:
Old Mar 12, 2003 | 09:20 PM
Racer16k's Avatar
Racer16k
Default Re: Oxygen Sensor (Chris81)
Well now I'm going to have to go buy one. Mine runs fine, but the idea that something that simple could make it better is too good to pass up. Good work Chris.
Old Mar 12, 2003 | 09:37 PM
PatsLs1vette
Default Re: Oxygen Sensor (Racer16k)
yes it was a 89 ford tbird 3.8 ,i previously was using a 4 wire ford 02 sensor.
Old Mar 12, 2003 | 11:45 PM
Chris69's Avatar
Chris69
Guess we probably all want to know now if it really matters which one is used as long as it fits and is heated and is zirconia... After I saw your post, I searched s'more and one guy said that he bought one for a ZR-1 (like the one I got) and it didn't work for him, so he tried the Ford sensor and it worked great. There was a reply to that saying that the ZR-1 sensor was probably just defective, that it should have worked just fine. This could drive one to drinking! :lol:
Old Mar 12, 2003 | 11:59 PM
BSeery's Avatar
BSeery
CI 6-7-8 Veteran
add in the fact that I am looking for one to run a gage on my truck and the other to run my fuel injection that I will be putting on my Vette. I want to get a heated for the Vette since I am running headers and the sensor will be way out at the reducers. I have to look again but I think my truck may have a place right in the manifold that I can screw one into.
Old Mar 13, 2003 | 01:41 PM
Dalannex's Avatar
Dalannex
-Justin
I don't know the part number for sure because i haven't picked it up yet, but if the 40 dollar bosch sensor listed below works that one would be cheaper. All 3 wire sensors have one odd colored wire, that one is the voltage to the ECM, the other two are heater wires.
Old Mar 14, 2003 | 02:49 PM
Widgett's Avatar
Widgett
I picked up the 13953 O2 sensor, now where can I find the mating weatherseal connector?
Old Mar 16, 2003 | 10:03 PM
  #33
Chris69's Avatar
Chris69
Default Re: Oxygen Sensor (Widgett)
I got mine at Pep Boys. Conduct-Tite brand for GM Weather Pack.
Housing - #85319
Male Pins - 85307
Cable Seals - 85305
Let us know how yours turns out.
