Door Panel Problem
Old Mar 9, 2003 | 08:08 PM
CrossedFlags77's Avatar
CrossedFlags77
Default Door Panel Problem
On my '77 the front top corner of the passenger door panel pops off alot. I take the panel off put it back on and then like a week later it will pop off again. I dont know if the metal that "clips" it on on top is bent or what. I cant tell. Any help would be appreciated.
Old Mar 9, 2003 | 08:34 PM
R. Bruno's Avatar
R. Bruno
Default Re: Door Panel Problem (RCDriveryo)
Sure sounds like the panel is tweaked in some way. It is (obviously) not normal for them to pop off. That steel piece on top should be very rigid.
Old Mar 9, 2003 | 08:36 PM
CrossedFlags77
Default Re: Door Panel Problem (R. Bruno)
Yeah I dont know whats wrong with it.
Old Mar 9, 2003 | 08:52 PM
R. Bruno's Avatar
R. Bruno
It may just be that the prior owner abused it. Maybe someone on the Forum has an old door panel you could try (even if it is the wrong color or torn) just to be sure that is the problem. I actually have old ones, but I believe your 77 is different than my early '76.
Old Mar 9, 2003 | 08:55 PM
CrossedFlags77
Yeah. Thats too bad.
To Door Panel Problem
