nitrous questions
Old Mar 9, 2003 | 09:39 PM
Perfomer's Avatar
Perfomer
Default nitrous questions
I am running a 327 with 175 hp shot with a set of 882 heads and 9.5 compression . The car ran 7.41 in the 1/8 with good 60ft of 1.66. I was running a/c plugs r45ts and 67 jets front and 71 rear. I changed to r42ts plugs and the car started breaking -up at 5500 rpm. Did I go to from in heat range or should I have went to a larger front jet? Timimg was at 32 degrees total.
