BRAKE PROBLEMS
Old Mar 10, 2003 | 04:58 PM
MIKE B - 82 CE's Avatar
MIKE B - 82 CE
Cruising
Default BRAKE PROBLEMS
HELP!!!!!
My brake light comes on when I depress the brake pedal. I just bought the car, and the light was not on during the test rides and ferry home.
My safety inspection said that the pads were at 50%, but the brake is very soft and travels way too much.
Can any of you experts point me in the right direction???
Old Mar 10, 2003 | 05:01 PM
Alwyn678's Avatar
Alwyn678
Default Re: BRAKE PROBLEMS (MIKE B - 82 CE)
First thing I would do is check the fluid and fill it up if it needs some
[Modified by Alwyn678, 5:01 PM 3/10/2003]
Old Mar 10, 2003 | 05:05 PM
MIKE B - 82 CE
Cruising
Default Re: BRAKE PROBLEMS (Alwyn678)
The fluid is up........
I don't think it is the master cylinder due to it not bleeding down, there just isn't much resistance at all....
Old Mar 10, 2003 | 05:12 PM
Larry B.'s Avatar
Larry B.
The light is turned on by a couple of things, but in your case it most likely is a leak somewhere as you say the pedal is soft.. If the switch detects a differential pressure between the front and the rear the light will turn on. Look closley at the calipers and fluid on the tires after the car sets for a while. Another thing to look for is rusted through brake lines. ANY loss of brake fluid will trip the switch. Once you corect the problem, it should reset.
Old Mar 10, 2003 | 10:21 PM
Bullyj's Avatar
Bullyj
Default Re: BRAKE PROBLEMS (silvervetteman)
Check to see if you have a caliper leaking.
Old Mar 10, 2003 | 10:26 PM
R. Bruno's Avatar
R. Bruno
Default Re: BRAKE PROBLEMS (Bullyj)
:iagree:
Old Mar 10, 2003 | 10:38 PM
captnpaw's Avatar
captnpaw
I had the same problem when I bought my vette. It turns out the caliper was cracked, flud leaking, and the brake lines were never bled. Hope this helps.
Old Mar 10, 2003 | 10:54 PM
PB82CE's Avatar
PB82CE
Mike, check my post...
I have had the same problem for 2 years...
Replaced the master, bled the brakes and still the same problem.
One caliper is probably bad and cannot be bled fully, so decided to do them all. Will let you know the outcome...
Old Mar 11, 2003 | 03:44 PM
MIKE B - 82 CE
Cruising
Thanks... I ordered 4 S/S Calipers and lines today. The weather will be too nice to work in the garage this weekend!!!
Old Mar 11, 2003 | 07:44 PM
PB82CE's Avatar
PB82CE
Make sure they are bled properly after installation, and make sure your master cylinder is working properly, if not, replace it... :yesnod:
Old Mar 11, 2003 | 08:30 PM
Superv's Avatar
Superv
Had the same problem,
Mine turned out to be the master cylinder although they can leak through the calipers. Changed the calipers, master cylinder and installed Braided hoses.
Probably only needed to change the master cylinder but hey!... While I'm at it. :banghead:
Old Mar 12, 2003 | 12:44 AM
Stevo81's Avatar
Stevo81
Default Re: BRAKE PROBLEMS (Superv)
I think we all waste some cash occasionally...missed diagnosis...but brakes is an area where it is OK to overdo it... :steering:
Old Mar 12, 2003 | 03:07 AM
Desertdawg's Avatar
Desertdawg
St. Jude Donor '09
Default Re: BRAKE PROBLEMS (Stevo81)
Well that shoots my comment all to heck.
I was going to say, just remove the bulb. :skep:
Old Mar 12, 2003 | 08:39 AM
MIKE B - 82 CE
Cruising
Default Re: BRAKE PROBLEMS (Desertdawg)
I'll change the master cylinder if the calipers don't do the trick. It is a safety issue that I would prefer to know that I have good equipment......just like having good tires!!
Hope my wife never finds out how much I am spending!!!!
Old Mar 12, 2003 | 10:49 AM
Missileman's Avatar
Missileman
If your not leaking fluid and not getting air from your calipers when bleeding but still have a mushy pedal then change your rubber brake lines. The inner liner can rupture and allow fluid to fill the cavity between the inner and outer sleeves reducing the volume to the calipers. Sometimes the outer liner will swell but not always.
Stock rubber lines cost about $15 a piece (cheap insurance since rubber was not designed to last forever). Teflon/kevlar/stainless braided are the way to go if you never want to replace them again and originality is not a factor.
Old Mar 12, 2003 | 12:53 PM
R. Bruno's Avatar
R. Bruno
If your worried about your wife and spending money on a c-3, you may want to take the time now to set-up a Swiss bank account. :D
Old Mar 12, 2003 | 03:09 PM
LFZ's Avatar
LFZ
:iagree: :iagree: :iagree:
Old Mar 12, 2003 | 03:28 PM
Koz
Guest
Posts: n/a
HELP!!!!!
Mike,
I don't know if this applies since we're talking about brakes.. BUT. Since you just got the car you have to do the 2 month cooling off period..
You'll be dumping money left and right into your ride before you know it..
Try to determine the problem before buying parts to fix it.. That's half the fun of owning the car..
If you just had a saftey inspection and they said you had 50% pad life then they took off the tires and inspected the brakes and calipers. I would think they would have told you if they saw a leaking caliper or you would see fluid on the tire/ground if you had a leak in the system. Your reservior would be low as well. Mushy pedal could be nothing more than air in the sytem. Gravity bleed the calipers you have first.. I'm not saying that 4 new calipers isn't a good thing.. :cheers: but try to figure out what's wrong first.. Good luck!
To BRAKE PROBLEMS
