Visor Disassembly
Old Mar 10, 2003 | 07:14 PM
CrossedFlags77's Avatar
CrossedFlags77
Default Visor Disassembly
I have a broken rod in my passenger visor and I purchased a new one. But when I pop off the little cap I dont know how to pop off the clips to seperate it from the windshield thing. Any help would be appreciated. :smash:
Old Mar 11, 2003 | 01:52 AM
Ric's80_4sp's Avatar
Ric's80_4sp
Default Re: Visor Disassembly (RCDriveryo)
I tapped gently a few times on the visor rod elbow (thing) with a punch and hammer and the elbow popped out. Replaced the elbow and used a socket slightly larger than the elbow rod to push the new clip onto the rod.
Hope this helps :smash:
Old Mar 11, 2003 | 10:44 AM
CrossedFlags77
Default Re: Visor Disassembly (Ric's80_4sp)
Mine doesn't have an elbow it is just an angled rod.
Old Mar 11, 2003 | 11:18 AM
Avette4me's Avatar
Avette4me
Cruise-In VIII Veteran
If I remember correctly, I got the new clip with my stuff, so I just used a punch, tapping easily but forceful and drove it out from the top. This broke the clip, but worked. I'm sure there's a better way and someone will chime in. Good luck.
Old Mar 11, 2003 | 01:33 PM
Ric's80_4sp
Elbow on the drivers side and bent rod on the passengers side. It worked for me on both just be careful and remember gentle hammer blows. :smash:
Old Mar 11, 2003 | 03:46 PM
boredsoIstrokedit's Avatar
boredsoIstrokedit
I used half of a piston ring from a blown up celica motor, sharpened up one end on the grinder, and picked the fingers holding the rod in place out. It worked good, but the clip was bent and I had to replace it anyways. I didn't want to use a hammer, as I already have a cracked windshield, and was a little nervous. PS, if you don't have a ring half laying around, a dental pic should work good too :lol: Good luck
To Visor Disassembly
