DO YOU KNOW?
Old Mar 11, 2003 | 11:05 AM
Ki m Le's Avatar
Ki m Le
Default DO YOU KNOW?
The checker flag on the emblems are different, between 68-75 and 76-82? Not the physical shape!
See who get the first correct answer.
Old Mar 11, 2003 | 11:10 AM
RCB69L36's Avatar
RCB69L36
Default Re: DO YOU KNOW? (Ki m Le)
Flags are reversed, aren't they? Meaning, the black and white on the checkered portion are reversed.
[Modified by RCB69L36, 10:13 AM 3/11/2003]
Old Mar 11, 2003 | 11:11 AM
Zack Wenning's Avatar
Zack Wenning
ummmm...What is the question exactly?
Old Mar 11, 2003 | 11:13 AM
Ki m Le's Avatar
Ki m Le
Default Re: DO YOU KNOW? (RCB69L36)
RCB69L36,
You're close but not the answer. Look a bit harder.
Old Mar 11, 2003 | 11:15 AM
Ganey's Avatar
Ganey
The no. of squares are changed. Even the question is in error. There are 3, not 2 changes in the no. of squares. Besides the black & white reversed.
[Modified by Ganey, 10:25 AM 3/11/2003]
Old Mar 11, 2003 | 11:35 AM
Ki m Le's Avatar
Ki m Le
Default Re: DO YOU KNOW? (Ganey)
Ganey, is correct, but the answer I'm looking for is the 68-75 checker flag has 4 rows of "squares" while the 76-82 has 3 rows!
So, if you remove the top row from 68-75's, you would end up with the 76-82's.
Hey Ganey, what are the changes you see that I don't?
Old Mar 11, 2003 | 11:44 AM
Neo Fender's Avatar
Neo Fender
Even on the same vehicle (i.e my 79), the checker patterns are different among the front, rear and side emblems.
Old Mar 11, 2003 | 11:48 AM
Ganey's Avatar
Ganey
This should be it or close.
68-72 4x4 squares 73-76 4x4 reversed
77-79 3x5
80 4x10
82 3x5 reversed
To DO YOU KNOW?
