lifting engine
Old Mar 12, 2003 | 09:56 PM
jetech's Avatar
jetech
Default lifting engine
I was told that using the stock front left lift bracket on an L48 with a aluminum performer manifold could crack the manifold, so I should fabricate a bracket that bolts to the front side of the left head. Can anyone back this up or will it be ok to use the stock bracket. thanks for any help.
Old Mar 12, 2003 | 10:17 PM
redwingvette's Avatar
redwingvette
Default Re: lifting engine (jetech)
I've used it on mine without any issues. I just bought a plate that bolts to the manifold by the carb bolt holes to use to put it back in. I can't see any reason using the stock lift plate would cause the manifold to crack.
Good Luck
Old Mar 12, 2003 | 11:48 PM
mapman's Avatar
mapman
Should not be a problem. I lifted the L-48 and transmission, as a unit, out of my 1980 (stock aluminum manifold) using the stock lift brackets- no problems.
Old Mar 13, 2003 | 12:20 AM
BSeery's Avatar
BSeery
From: Exiled to Richmond, VA - Finally sold my house in Murfreesboro, TN ?? Corner of "Bumf*&k and 'You've got a purdy mouth'."
CI 6-7-8 Veteran
CI-VIII Burnout Champ
St. Jude Donor '06-'10, '13
Default Re: lifting engine (mapman)
we pulled my L-48 out with no problems at all. Never heard about a manifold breaking from this before.
Old Mar 13, 2003 | 12:38 AM
boredsoIstrokedit's Avatar
boredsoIstrokedit
Wouldn't worry, but a carb lift plate can be found for $20 or so, and it may be worth having if you lift engines without lift plates. I have also seen them lifted with a pair of longer bolts in two intake bolt holes. :cheers:
Old Mar 13, 2003 | 04:59 AM
tshort's Avatar
tshort
CI 7-8 Veteran
Default Re: lifting engine (boredsoIstrokedit)
I used a balancer bar and then bolted the chains to the accessory holes in the heads. Came out real easy along with the tranny.
Old Mar 13, 2003 | 12:23 PM
Oldguard 7's Avatar
Oldguard 7
Default Re: lifting engine (tshort)
Have any more of engine lifting pics shot at different angles? If so pls post.
Old Mar 13, 2003 | 02:46 PM
76greg's Avatar
76greg
:iagree: with tshort. That is exactly how I pulled my L48 with the TH350 auto attached! Get some grade 8 bolts and washers to attach the chains to the accessory holes in the heads. Load leveler is a must have item. You can finesse that motor trans combo right out without scratching the fenders or anything else. :D
Greg :cheers:
Old Mar 13, 2003 | 03:42 PM
tshort's Avatar
tshort
CI 7-8 Veteran
Default Re: lifting engine (Oldguard 7)
Sure, here's one below. As an added bonus you get to see my dad in the picture too. You can also go to my webpage and view these and more under the 383 Stroker Install pages. Enjoy.
To lifting engine
