81 Turn Signal help....
Old Mar 14, 2003 | 08:52 PM
81ZZ4's Avatar
81ZZ4
Default 81 Turn Signal help....
My Flashers work fine. All lamps are fine, brake, side markers etc.
Turn signal wont flash left or right side.
I can do it manually with turn signal lever on both sides but no flash.
Can the flasher unit work for just the 4 ways?
Whats up here??? :withstupid:
Old Mar 14, 2003 | 09:24 PM
VETJET's Avatar
VETJET
Default Re: 81 Turn Signal help.... (81ZZ4)
I had the same problem with my 81 and I beleive that I corrected it by changing the bulbs. Even though they all appeared to work changing the bulbs corrected the problem and I beleive that it was the curb illumination bulb on the right side that I suspected to be the culprit.
Old Mar 14, 2003 | 09:43 PM
53ANNV03's Avatar
53ANNV03
8th Gear
Turn on your parking lights and the 4way hazzard, check all bulbs if working, and see if improper bulb (1034 instead of 1157). If bulbs are OK you may have to replace signal switch.
I'd replace the turn signal flasher first though, and check the purple wire connectors at column and possibly clean contacts.
If you have the factory manual it's in section 8B for further diagnosis.
Good luck with yours. ;)
Old Mar 15, 2003 | 12:23 AM
81ZZ4's Avatar
81ZZ4
Default Re: 81 Turn Signal help.... (53ANNV03)
Thanks Guys :yesnod:
To 81 Turn Signal help....
