Rock Hard Radiator Hoses...
Old Mar 15, 2003 | 04:26 PM
joeveto's Avatar
joeveto
Cruise-In IV Veteran
Cruise-In V Veteran
St. Jude Contributor
Default Rock Hard Radiator Hoses...
I'm not sure what to make of this. My upper and lower radiator hoses are rock hard. The car has coolant, the heater blows hot air when requested.
The car doesn't appear to be overheating. But I relocated my temp sensor to the water outlet after the rebuild (the Vortec heads wouldn't accept the sensor).
My fear, is that the thermostat is locked closed, and that's why the hoses feel as they do. In the past, they've always been soft, and you could almost feel the coolant going through them. Am I crazy? Is there a problem here?
Thanks. :crazy:
Old Mar 15, 2003 | 04:35 PM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
Default Re: Rock Hard Radiator Hoses... (joeveto)
This is just a guess but, You may have been feeling of the hoses when the thermostat was open. Maybe it is closed now. Try running the car up to temp and then see if the hoses arent soft.
Old Mar 15, 2003 | 04:38 PM
79VetteMike's Avatar
79VetteMike
Stop squeezing on your hoses and they will probably stay soft... :lol:
Old Mar 15, 2003 | 05:32 PM
Larry B.'s Avatar
Larry B.
They should be hard after the system builds pressure. The pressure cap maintains the pressure at whatever the rating of the cap is. With 15psi the hoses will be very hard. If you run the car without the cap then there will be no pressure and soft hoses. :cheers:
Old Mar 15, 2003 | 07:04 PM
Jvette73's Avatar
Jvette73
After the rebuild you probably sealed up some internal leaks and such. Now the sys is building and holding pressure which is a good sign. Just make sure all yur hoses are in good shape so they dont blow out. Check every inch of every hose, rad and heater hoses, especially where they might cross over and touch things. Sometimes they will chafe and cut, then eventually blow out. I wrap my hoses in with cut sections of hoses split down the middle and secure in place with zip ties. This protects the hose from being cut where it contacts other things.
Old Mar 15, 2003 | 07:52 PM
Jughead's Avatar
Jughead
Senior Member since 1492
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
Default Re: Rock Hard Radiator Hoses... (79VetteMike)
:lolg: :lolg: There's 1-2 in every crowd. :D
Old Mar 16, 2003 | 09:40 AM
joeveto's Avatar
joeveto
Cruise-In V Veteran
Thanks guys.
It's weird, but once I start squeezing, I just can't stop...
:thumbs:
Old Mar 16, 2003 | 10:35 AM
BTRNSEX's Avatar
BTRNSEX
Wish my hose was rock hard :D
Oops!!!! wrong forum :bb
[Modified by BTRNSEX, 9:36 AM 3/16/2003]
To Rock Hard Radiator Hoses...
