Hatch Back Conversion
Old Mar 15, 2003 | 05:01 PM
dsagers's Avatar
dsagers
Default Hatch Back Conversion
Thinking about converting my 1981 to a hatchback by using the parts from a 1982. I found a wrecking yard that has all the parts, but I don’t know if there are other modifications that will need to be made to the ’81 for this conversion.
Anyone have any knowledge or experience with this conversion?
Old Mar 15, 2003 | 05:20 PM
JRODDVETTE's Avatar
JRODDVETTE
Default Re: Hatch Back Conversion (dsagers)
i am also interested in any available info.
Old Mar 16, 2003 | 01:32 AM
BSeery's Avatar
BSeery
From: Exiled to Richmond, VA - Finally sold my house in Murfreesboro, TN ?? Corner of "Bumf*&k and 'You've got a purdy mouth'."
CI 6-7-8 Veteran
CI-VIII Burnout Champ
St. Jude Donor '06-'10, '13
Only the 1982 CE's had the opening hatches. The glass is VERY expensive and rare.
There is a lot of work to be done and from the people who have them, they wish they were sealed up. Most wind and water leak, have problems with hinges or weatherstripping and the struts don't work anymore.
Old Mar 16, 2003 | 03:32 AM
Desertdawg's Avatar
Desertdawg
St. Jude Donor '09
Default Re: Hatch Back Conversion (BSeery)
Yep, wind and water leaks, bent hinges, and worn out lift struts.
The rear hatch is a great item, but it was more of a R&D item for the C4 that needed lots of refinement. Look at a C4 and you will see that they didn't use any of the 82 design.
You will also need the $250.00 gasket, I'm sure the junkyard one will not come off in one piece.
To Hatch Back Conversion
