69 vacum hose
Old Mar 16, 2003 | 01:15 PM
telk's Avatar
telk
Default 69 vacum hose
There is a small vacum hose with a yellow or tan stripe coming out of firewall into engine compartment under wiper door limit switch that is just hanging.
End is burnt looks like it touched exhaust manifold. There is suction on the hose but i cant tell where it went. Any ideas. The car has AC if that helps.
Thanks Telk
Old Mar 16, 2003 | 09:58 PM
RCB69L36's Avatar
RCB69L36
Default Re: 69 vacum hose (telk)
Is this the hose you happen to be asking about? I found this one not connected in my '69 too. Check out the thread below the picture for some insight. I have not hooked it up to the vacuum system yet, so I don't know what its function is.
BTW...I do not have AC in my car.
http://forums.corvetteforum.com/zerothread?id=512781
[Modified by RCB69L36, 9:25 PM 3/16/2003]
Old Mar 16, 2003 | 10:25 PM
RCB69L36's Avatar
RCB69L36
So, I'm looking through the 69 Assembly Manual and on page 143 there is mention that you have to cut the wiper vacuum hose running between the wiper actuator and the main vacuum canister to connect the heater/AC vacuum control hose. Instructions on my new ZIP vacuum hose kit say the same thing and that you'll have to use the existing "T" to connect it because ZIP doesn't include it in the kit. There is no existing "T" (part number 3929022) on the hose I've shown in the picture above and I can't find that part number in any of the supplier catalogs, so I can't even tell if this is the right hose I'm supposed to connect to.
It's a VERY small hose, much smaller than any hose in the regular vacuum system. It appears to run directly into the heater motor area, so I can only assume that this is what the hose is for, but now I need to find the right "T" to connect it.
Any ideas where to find this piece? It can't cost more than $ .50
And, can anyone check their 69 to see if we're right on this? Thanks.
:confused:
Old Mar 16, 2003 | 11:10 PM
Corvettes White's Avatar
Corvettes White
It might be the line to the water shutoff valve. Turn the AC controll to "heat" then you should loose the vacume.
Old Mar 17, 2003 | 10:27 AM
telk's Avatar
telk
Default Re: 69 vacum hose (RCB69L36)
Yes that looks like te hosein your picture.
To 69 vacum hose
