How to remove the inserts
Old Mar 19, 2003 | 07:35 PM
69vette66's Avatar
69vette66
Default How to remove the inserts
Any tips on how to remove the inserts on hooker side pipe mufflers, They have the glasspacks in them. I have been soaking them with WD and other various type of pentrating oils. I used a board with a hole in the middle a put a chain through it connecting it on the the other end of pipe with a 1/8 inch piece of steel with a notch cut in it, and it just ripped in two when I hooked up the port-a-power. any ideas?
Thanks Larry :cheers:
Old Mar 19, 2003 | 07:46 PM
1Bad69's Avatar
1Bad69
Default Re: How to remove the inserts (69vette66)
mine were rusted in ...lots of pounding with small sledge, lots of WD, and also a few chisels....
Old Mar 19, 2003 | 09:47 PM
yellow 72's Avatar
yellow 72
St. Jude Donor '09
I've had the best luck by holding the tube vertical and dropping the open end on a piece of wood. The hammering impacts will sometimes break them loose :cheers:
To How to remove the inserts
