76 front suspension drop
This is a common thing. Been there done that.
Most fix it one of a couple of ways. Depends on how you drive the car and the ride you are looking for.
Some, like myself, swap out the stock springs and install 460lb springs (cost about $80). This lowered my car over an inch and the ride is still comfortible.
Others have gone with the 550lb springs. This brings it down further but I believe to be a firmer ride.
Others have just cut a coil or coil and a half off of either the stock or 460lb springs to get it where they want it.
I'd say go with the 460's and try it. They are not that hard to change (docs available and see http://www.corvettefaq.com). If you cut the 460's and it's too low, you then have to replace the springs.
Also, check everything else while under there - ball joints, tie rods, control arms and bushings, brakes and brake lines, steering). When all done, have it realigned (4 wheel).
Enjoy!
:auto:
