Poly or Rubber Differential Mounts?
Guest
Posts: n/a
Would you feel any more vibration with a poly mount over rubber..? New rubber which includes the metal sleve is $16.50. Polly at Muskegon is $9.95 but I have to use my metal sleve.. Since Polly is usually more expensive I'm wondering if there's a down side when using it for the differential mount.. Thanks
Re: Poly or Rubber Differential Mounts? (Koz)
I had my beat up rubber differential mount replaced last summer with a poly. Did not notice any vibration at all. Since old mount was worn/torn/no good, actually improved drivetrain overall with the poly. Recommend poly.
