Windshield replacement tips/tricks/ warnings
I was also going to use a modern windshield urethane sealant when I get around to putting in back in. I'm I going down the wrong road with that or should i use the OEM stuff. :smash:
I do remember him mentioning that back then they used butyle or something to seal windshields. He said it did a terrible job and attracted moisture. He used a urethane seal kit going back in, I am very pleased.
I shouldn't laugh, as it is possible. Do not try to pry it out - AT ALL.
The preferred method to remove these is with a piece of piano wire and two
wooden handles. I've never done it - but I assume any stiff but flexible steel
wire may work. The idea is to push the wire through the adhesive - between
the glass and frame. Wrap each end of the wire onto a wooden handle (piece
of thick dowel). Now, using the two handles, pull back and forth in a sawing motion as you also force the wire to cut through the old adhesive. After
cutting around the entire perimeter - the glass should push out easily.
If not, go back to where it seems to be sticking and get the adhesive loose.
It helps to have a helper for this one - not only to pick the glass up - but
also to use the wire around the bottom. DO NOT PRY ON EDGE OF GLASS !!!
Prying on it will guarantee a cracked windshield.
Good Luck. :seeya
[Modified by NHvette, 4:11 PM 3/26/2003]
Hire someone. It will be the best $40 you spent.
Gary
One suggestion, if you're going to do it yourself: get something fairly heavy duty, but flexible, to cover your dash. As you use a long knife or hacksaw blade or something similarly long and flexible to cut the sealant along the bottom of the windshield from inside the car, you need to protect the top of the dash.
Also, the new glass presents the ideal opportunity to change out the A-pillar weather stripping, as it will be removed to release the windshield trim.
[edit] Oh, yeah, about the cost: The whole deal was covered under the comprehensive part of my auto policy, with the $50 deductible being waived. So there was ZERO incentive for me to do it myself.
Good luck with it! :seeya
[Modified by Gator81, 3:07 PM 3/26/2003]
