400 small block
Old Mar 27, 2003 | 07:28 PM
sidepipes79's Avatar
sidepipes79
Default 400 small block
I just found a 400 cid short block with crank for $150. I have a machine shop that will bore it out to a 406 for lil or nothin. i am just wondering what i would have to do and how much it will cost to get about 450 to 500 horse out of it. I plan on putting it into my 79 daily driver. thanks
Old Mar 27, 2003 | 08:06 PM
The Money Pit's Avatar
The Money Pit
Default Re: 400 small block (sidepipes79)
I've got around $5000 in mine,but you can do it cheaper than that. I went with billet pulleys,aluminum heads and petty much top of the line everything. Even the bolts are ARP or stainless steel. Check out my site for the buildup article that got me started on this. I guesstimate 500hp with what I've got in it based on buildup articles and past experience with 350's.This one rocks! :cheers:
Old Mar 27, 2003 | 08:31 PM
sidepipes79
Default Re: 400 small block (The Money Pit)
Do you have any problems with averheating or anyhtign like that? did you do all your own work?
Old Mar 27, 2003 | 08:42 PM
PatsLs1vette's Avatar
PatsLs1vette
i never had any trouble with overheating on any of the 400 i ran,as long as you have the steam holes drilled in non 400 heads youll be fine.Build the 406 yoll love it,just dont crazy on compression.
Old Mar 27, 2003 | 08:47 PM
79Corvette02's Avatar
79Corvette02
Just out of curiosity, what do you have in there now? I noticed the times in your sig, and got jealous :p:
Old Mar 27, 2003 | 09:50 PM
427V8's Avatar
427V8
C6 the C5 of tomorrow
Default Re: 400 small block (patsnitrovette)
Do it.
You can build a 400 as cheaply or as expensively as you want!
But it will always have more power than the same $$ in a 350...
Old Mar 27, 2003 | 11:44 PM
sidepipes79
Default Re: 400 small block (427V8)
That time was posted in a GM goodwrench crate motor, moderate cam, and a fuel pump that had a 3/4 inch hole in the diaphram. i am runnign 3.08 rear end. This winter i put a new stock fuel pump, and a 700r4 in. I should be goin to the track next sat. well see. I am hoping for mid 13s. but i want to built a motor to get me in the 11s.
Old Mar 28, 2003 | 08:46 AM
The Money Pit
I had an overheating problem before the new aluminum radiator.Pushing around 500hp with 10:1 CR will do that.If someone tells you a stock smallblock radiator is all they run,and they claim 500hp,most likely they're pulling the wool over your eyes.I've run plenty of 350hp 350's and got away with stock radiators before.The 406 would run OK for 20-30 minutes,then the temps would start to creep up with the stock radiator.Now it runs 190 tops.
Old Mar 28, 2003 | 03:38 PM
midwest-vette's Avatar
midwest-vette
I'd guess around a couple grand would get you to the 500 hp mark considering you're starting with a block and crank. Probably less if you have all the other components to get it running. My 400 sbc has nickle and dimed me to the poor house. It seems I'm always adding something. No problems with the engine overheating, of course I don't come close to 500 hp.
To 400 small block
