Rear diff interchangeability
Old Mar 27, 2003 | 11:41 PM
Berserker78's Avatar
Berserker78
Default Rear diff interchangeability
I have a 78 that I want to swap out the rear end in, but I cannot find anything that will tell me what years are interchangeable with it.
Berserker
Old Mar 27, 2003 | 11:44 PM
LAvetteman's Avatar
LAvetteman
St. Jude Contributor
Default Re: Rear diff interchangeability (Berserker78)
1965-1979 diffs are interchangeable
1980-1982 are interchangeable.
Old Mar 28, 2003 | 12:10 AM
Glensgages's Avatar
Glensgages
Default Re: Rear diff interchangeability (71,454,4spd)
71,454,4spd, is it possible to use the '65-'79 center section with the '80-up axles, etc.? I'd think the 'early' diffs are stronger than the 'later', ones, correct? I'm considering mods to my Cross-Fire, and don't wanna be towing my C3 home from the strip. Is it possible to 'beef-up' the Dana-44, found in '80-'82 Corvettes? Can anybody offer ideas? :confused:
Old Mar 28, 2003 | 01:08 AM
Aaron-74's Avatar
Aaron-74
Default Re: Rear diff interchangeability (Glensgages)
If anything is going to be making you be towed home, it's that trans. Don't expect the stock 82 700R4 to last too long. They're pretty weak...Our 82's has gone out on us twice now. And I don't think it's got 90,000 miles on it.
Old Mar 28, 2003 | 01:19 AM
Glensgages's Avatar
Glensgages
Default Re: Rear diff interchangeability (Aaron-74)
Thanks, Aaron-74. I 'might' have that problem under control. At the very least, we'll rebuild & bullet-proof the OEM 700R4. If I don't have a 'cracked' iron head and need a set of aluminum heads, I'll use that $ for a 'built' heavy-duty TCI 700R4. Either way, I'm throwing a TCI higher-stall/lock-up converter in there, too! (I have a 'built' short-shaft, 2.75:1 low-gear THM400 in my garage, too) The differential has me a bit 'scared'.....
Old Mar 30, 2003 | 01:54 PM
jimtreber's Avatar
jimtreber
I swapped out my 1976 differential with one from a 1964 that had original 4.11's. All I had to change was the yokes and it was ready to go.
1976 406 TH400 4.11 nitrous
Old Mar 31, 2003 | 12:38 AM
LAvetteman's Avatar
LAvetteman
Glen, the mounts to the frame are different on the different rears. I think the yokes and the half shafts are different as well.
I wouldnt worry about the DANA's to much.
Old Mar 31, 2003 | 03:40 PM
Van Steel's Avatar
Van Steel
Premium Supporting Vendor
QUOTE
You can also put the aluminum cover off the 80-82 on the 65-79 housing. You'll have to mod the rear. We are currently doing one. We are also dropping a 5 speed in the car. If i can ever find my digital camera i'll take some pic so you guys can see.
Old Mar 31, 2003 | 04:33 PM
TedH's Avatar
TedH
1980-82 interchangability: Automatics share the same side yoke/half shafts on 80-81, manual trans cars' side yokes/half shafts are beefier/larger. Not 100% interchangable.
I'm assuming on '82, since only automatics were offered, the side yokes and half shafts are same dimensions as 80-81 auto cars.
Old Mar 31, 2003 | 07:20 PM
BSeery's Avatar
BSeery
From: Exiled to Richmond, VA - Finally sold my house in Murfreesboro, TN ?? Corner of "Bumf*&k and 'You've got a purdy mouth'."
CI 6-7-8 Veteran
CI-VIII Burnout Champ
St. Jude Donor '06-'10, '13
Default Re: Rear diff interchangeability (TedH)
1980-82 interchangeability: Automatics share the same side yoke/half shafts on 80-81, manual trans cars' side yokes/half shafts are beefier/larger. Not 100% interchangeable.
The rear ends are interchangeable. It's the yokes that are different. If you are putting a rear end from a manual into a car that has an auto, just slip the auto yokes into the rear end. The other option is to change U-joints to ones that will adapt the manual side yokes to the auto 1/2 shafts. I did the latter.
To Rear diff interchangeability
