Voltage dropping.....
Old Mar 28, 2003 | 04:19 PM
72Shark's Avatar
72Shark
Default Voltage dropping.....
So what's wrong now?? Starts at 13 volts, and within minutes is below 12 and still dropping. This is a brand new "Tuff Stuff" 80 amp chrome alternator from Jeg's. Less than 45 minutes of running time on the car. Thoughts???
Old Mar 28, 2003 | 04:27 PM
Jvette73's Avatar
Jvette73
Default Re: Voltage dropping..... (72Shark)
What kind of voltage gauge are you using? It could be the gauge reading low. Fluctuating a volt or two is not nessisarily a problem. what happens to the reading when you turn accesories on. Like wipers and heater and such. you couls check the gauge on another car to see what it reads. Im assuming yur using a hand held voltmeter. Does you car still have the engine ground strap in place? Just tossin a few ideas out there.
Old Mar 28, 2003 | 04:40 PM
LAvetteman's Avatar
LAvetteman
St. Jude Contributor
Is your battery staying charged? If so, then its normal, your alt is slacking off as load decreases. Turn on your lights and see what happens.
Old Mar 28, 2003 | 05:47 PM
Jim 77's Avatar
Jim 77
Default Re: Voltage dropping..... (71,454,4spd)
I had a similar problem. I had some strange electrical quirks, and an appetite for alternators. If you have a bad connection, you could wear out an alternator very quickly.
My problem was a bad connection at the starter- the positive battery cable was bad.
To Voltage dropping.....
