'77 heater control Q's
Old Mar 28, 2003 | 09:24 PM
johnnyc's Avatar
johnnyc
Default '77 heater control Q's
I replaced the heater control assy on my buddy's '77 because the vacuum manifold portion of it was in pieces. We still can't divert the air to the AC ducts and defogger vents. There is vacuum getting to the switch, and every thing else seems to be OK. Where else should I look :confused: :confused:
Thanks----John
Old Mar 28, 2003 | 10:54 PM
Ganey's Avatar
Ganey
Default Re: '77 heater control Q's (johnnyc)
Probably the vac. switch itself is not switching due to vac. leak as the usually plastic rivet is not holding the 2 main switch parts together well. Besides replacing, it is also possible to tighten this &/or lube w/ a thin layer of white lithium grease or vasoline to fix.
:cool:
Old Mar 28, 2003 | 11:25 PM
johnnyc's Avatar
johnnyc
Thanks Ganey, I'll give that a shot....JC :flag
To '77 heater control Q's
