brake caliper rebuild
Old Mar 29, 2003 | 09:33 AM
jetech's Avatar
jetech
Default brake caliper rebuild
I found that my right rear caliper isn't doing anything when the brakes are applied. I have never rebuilt one before and was wondering what is involved and is it worth it to rebuild or just replace. When I tried to bleed the brake, no fluid came out. The disc looks like the pads haven't touched it in a while and there is a grime buildup on the disc that indicates a leak. I have only driven this car a few times so I will keep an eye on the reservoir level.
Thanks for any help.
Old Mar 29, 2003 | 10:05 AM
wombvette's Avatar
wombvette
Default Re: brake caliper rebuild (jetech)
I would suggest that you just go and get a rebuilt one, preferably stainless steel. It will be cheaper in the long run. The kits are expensive at local parts stores and the pistons etc will be rotten if its as bad as you say. You should also change the rubber hose , as that may also be the problem.
