timing (again)
Old Mar 29, 2003 | 11:16 AM
jetech's Avatar
jetech
Default timing (again)
After running on the new cam and manifold for a few hours I checked timing again and this is what I have.
Intitial @ 700 - 1000 RPM = 12 deg.
Reved up above 1000 RPM with vac adv removed = 38 deg.
reved up with vac adv hooked up = 48 deg.
The guy that helped me with the engine work is telling me to just leave the vac advance disconnected. What do you guys think. :confused:
Old Mar 29, 2003 | 08:36 PM
joeveto's Avatar
joeveto
Cruise-In IV Veteran
Cruise-In V Veteran
St. Jude Contributor
Default Re: timing (jetech)
That's way too high. Is it pinging? It sounds as though you have the distributor in wrong. 34 to 36 degrees is the maximum amount of advance most sb Chevy's will stand.
Old Mar 29, 2003 | 09:28 PM
LAvetteman's Avatar
LAvetteman
Default Re: timing (joeveto)
From what I have seen that is normal. Some engines can run with more than 50 deg total advance.
Old Mar 29, 2003 | 10:37 PM
Perfomer's Avatar
Perfomer
I would check the mech advance springs under the rotor button ,sounds like they are broke or weak. I would get a recurve kit and start with the middle springs. set the int. timing with vac. advance disconnected at 8degs and connect the advance and check total at 3000rpm should be 36-38 degs if not adjust to 36-38 and check int with advance disconnected . You may have to change springs to get timing right but by no means leave the vac. advance disconnected they put it there for a reason. (Driveability and better fuel mileage)
Old Mar 29, 2003 | 10:44 PM
Jvette73's Avatar
Jvette73
Default Re: timing (Perfomer)
38 without the vacuum connected is just right. Be aware that vacuum advance is negligable at full throttle since thers practically no vacuum available at full throttle. Disconnecting the vacuum advance will not effect your full throttle performance. It will however effect your part throttle response. If you have no pinging youll get better mileage and throttle response with it connected. Your #'s sound right to me. One question. Do you have the vacuum line connected to a full vacuum source or a ported vacuum source? In my opinion the ported source will work better overall, but there is always debate on the subject.
Old Mar 30, 2003 | 08:17 AM
jetech's Avatar
jetech
Default Re: timing (Jvette73)
I have the vac adv hooked to the port where it was hooked up to before (front upper left) on the carb. I am sure the distributor is in correct and the springs and weights are ok. Could it be because the only smog stuff left on the engine now is the cat and vapor canister so now the original vac adv is the wrong set up and the engine is no longer so de-tuned?
Old Mar 30, 2003 | 12:55 PM
jimtreber's Avatar
jimtreber
You say revved up above 1000 = 38deg. How much above 1000? Are you sure you are revving high enough to get full advance. If you have stock springs and weights you're looking at appx 4500.
38 deg. isn't a problem. When I had an L48 with Comp Cam 368, it was happiest with 40.
Point 2. If you haven't degreed you dampener, your timing is apprximate. Chevy dampeners are notorious for the outer ring slipping and rotating with age.
1976 406 12to1 CR, TH400 3000 swich pitch, 4.11, nitrous
Old Mar 30, 2003 | 08:57 PM
Vetterodder's Avatar
Vetterodder
Active Streak: 90 Days
And the problem is? I don't see any problem with those specs but I am suprised that your vacuum advance is only adding 10º. Are you sure that the 48º reading was taken with it revved high enough for all mechanical advance to be in? Like Jim posted, max advance on some stock distributors doesn't arrive until around 4,500 rpm.
Old Mar 30, 2003 | 10:56 PM
jetech's Avatar
jetech
Default Re: timing (Vetterodder)
Next weekend when I get a chance I will get some more accurate numbers. I guess the one thing that I really don't like is the 48 with vac. I am pretty sure I had the rpm's up there but I will make sure. Thanks to all of you for your input. :cheers: :flag
Old Mar 30, 2003 | 11:14 PM
Stefan69's Avatar
Stefan69
Don't worry about the 48 deg with vac. With vac -not at full throttle!- I get 54 degrees and she is not pinging. That is just to lower emmissions and boost fuel economy. The only worry is when she pings.
Read Lars' tech paper on the subject of timing and you will sleep much better with 48 degrees and more... http://www.corvettefaq.com/c3/HowToSetTiming.doc
Enjoy driving it!
Stefan :seeya
Old Mar 31, 2003 | 12:03 AM
cardo0's Avatar
cardo0
From: Las Vegas - Just stop perpetuating myths please.
:iagree: Sounds like Jvette73 nailed your problem jetech. The only job the vacuum advance has (that Iv'e heard of) is at low RPM/ low load but high manifold vacuum to roadblock predetonation. Correct me if I'm wrong but vacuum advance allows enough advance at idle/low RPM and falls off as RPM increases (manifold vacuum decreases) - then the distributor wieghts & springs do thier thing.
If your hooked to a ported vacuum it would explain the higher advance at high RPM with vacuum connected and normal (?) advance at high RPM while disconnected.
The Forum use to have a tech section with common question & answers. You may find some carb pix with vacuum hose routing with a search. I have one on the hard drive for a 350 Qjet and if I knew how to post it I surely would. :rolleyes:
To timing (again)
