Need Input from Composite Spring Users
Old Mar 30, 2003 | 09:38 PM
OldSchool's Avatar
OldSchool
Default Need Input from Composite Spring Users
I have been kicking around the idea of changing to a Composite rear spring. Can anyone tell me if the ride improves that much. I have the old original spring out, and it needs new rubber between the springs. Is it worth restoring? What about testing for strength? It seems easier to get a Composite and bolt it in. Does everyone use the heatshield on the spring? Doesn't that kind of look like crap? Thanks for your help . :skep: :smash:
Old Mar 31, 2003 | 12:02 AM
Jon69L46's Avatar
Jon69L46
Default Re: Need Input from Composite Spring Users (OldSchool)
Well it's probably not a fair comparison to judge a 30+ year old steel spring, to a new fiberglass one. But in my case the ride reallllly improved. I've got a 330 lb. from VBP, and like it pretty well. It might be a tad soft, but I'll know better when I finish the front, and the spring rates are a better match.
Easy installation. Also I've gotten under there right after a long trip and the spring seems cool to me.
Jon
Old Mar 31, 2003 | 12:49 AM
1979toy's Avatar
1979toy
I've also got the 330 lb VB&P spring. It is the single best improvement that I have done to my car. My stock 9 leaf spring was shot and the weight savings, 35 lbs, was enough to make me want the glass spring. I'm very glad that I made the change. Be sure to get shocks that are designed for the glass spring.
Old Mar 31, 2003 | 10:06 AM
OldSchool's Avatar
OldSchool
Thanks for the input.. So you are saying that you run without the heatshield..Is anyone else doing this? thanks again
Old Mar 31, 2003 | 10:46 AM
Gordonm's Avatar
Gordonm
I have the 330 VBspring without a heat shield and no problems in 4 years
Old Mar 31, 2003 | 07:29 PM
Duke94's Avatar
Duke94
Having the right shocks is important. When I bought my 71' it had the plastic spring and no-name cheap shocks. It bounced LOTS in the rear. I changed to the VBP "special" shocks and it rides very well now.
Old Mar 31, 2003 | 08:13 PM
Bobchad's Avatar
Bobchad
Default Re: Need Input from Composite Spring Users (Duke94)
I understand that the AC Delco Reactec shock will work with the composite spring. Is that correct?
Old Mar 31, 2003 | 08:14 PM
Crickett's Avatar
Crickett
For those of you that purchased VBP springs....would you recommend the 330 or 360 lb spring??
Old Mar 31, 2003 | 10:05 PM
BSeery's Avatar
BSeery
From: Exiled to Richmond, VA - Finally sold my house in Murfreesboro, TN ?? Corner of "Bumf*&k and 'You've got a purdy mouth'."
CI 6-7-8 Veteran
CI-VIII Burnout Champ
St. Jude Donor '06-'10, '13
Default Re: Need Input from Composite Spring Users (Crickett)
I have a 340lb rate TRW design spring in mine for 2 years now. SOOOOO SMOOOOOTH !!
You do have to have shocks to match. I bought a set of externally adjustable 9 position shocks from Mid America. The set of 4 is $200, a price you can't beat for externally adjustable shocks.
Old Mar 31, 2003 | 10:06 PM
BSeery's Avatar
BSeery
CI 6-7-8 Veteran
Default Re: Need Input from Composite Spring Users (BSeery)
P.S. -- I have the heat shield, I have to. I have both pipes tucked right under it and without it the spring could melt, de-laminate, warp or do other ugly things.
Old Mar 31, 2003 | 10:09 PM
Crickett's Avatar
Crickett
I was thinking about getting edelbrock shocks....I wonder how they'll work.
Old Apr 1, 2003 | 02:20 AM
1979toy's Avatar
1979toy
We don't need no sticking heat shields....we gots side pipes. :thumbs: :lolg:
Old Apr 1, 2003 | 04:58 PM
Crickett's Avatar
Crickett
Default Re: Need Input from Composite Spring Users (1979toy)
I've heard a couple guys say the 330 lb spring is great, but a little soft. I think I'm leaning toward the 360 lb. :cool:
Old Apr 1, 2003 | 05:04 PM
GrandSportC3's Avatar
GrandSportC3
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
My fiberglass spring made a big difference in riding comfort..
Old Apr 2, 2003 | 03:41 AM
2BAD's Avatar
2BAD
:cool: That's really nic price but are they really good ???
I heard that 5 or 9 ways adjustable shocks can be used at the track as 90/10 drag shocks yet you can use them for autocrossing ,street racing.....etc ! :confused:
Is this right ??
Old Apr 2, 2003 | 04:03 AM
Graemeinvette's Avatar
Graemeinvette
Default Re: Need Input from Composite Spring Users (2BAD)
I have the 330 rear without a heat shield for about 5 years and no problems. I matched it to 460 fronts with a bigger sway bar and it handles so well :D now. very predictable in oversteer :thumbs:
To Need Input from Composite Spring Users
