Update on Engine, and then some ...
Here's a couple before shots ....
and here's the after ...
The total rundown on the car is as follows:
New GM Performance ZZ4 Heads (L98): $847.63
58cc Chamber, Angle Plug Heads with:
Pro-Flow Swirl Polished Stainless Valves, LT-1 Valve Springs Good to .530 Lift, Chrome-Moly Retainers and screw in studs, Hardened Guide Plantes and Valve Locks
Edelbrock Performer Intake 2101: $130.99
Aluminum Wire Looms: $30.82
Accel Custom Fit Wires :$30.82
Yellow Snap-On Wire Protector: $6.16
Chrome Alternator: $107.88
Chrome 15 5/16" Air Cleaner Lid: $30.82
Chevrolet Chrome Dress Up Kit: $69.35
ARP Rod Bolt Kit 134-6403: $111.29
ARP Engine Bolt Kit 534-9601: $178.03
Carter Mechanical Fuel Pump: $41.31
Cloyes Double Roller Timing Chain 9-3100: $149.50
Clevite Main Bearings MS909P10: $61.49
Clevite Rod Bearings CB663P10: $45.82
Comp Cams Xtreme Energy Camshaft: $217.35
Valve Lift: .477i, .480e; Sae Dur: 268i, 280e;
.050 Dur: 224i, 230e, Part 12-242-2
Durabond Cam Bearings CHP8: $58.13
Engine Paint: $19.62
Federal Mogul Roller Tip Rockers R1024R: $253.18
Federal Mogul Hydraulic Lifters HT817: $98.99
Federal Mogul Ring Set E251K40: $82.20
Fel-Pro Premium Rear Seal 2912: $39.23
Fel-Pro Oil Pan Gasket 1803: $22.08
Fram Oil Filter PH13: $7.54
Keith Black Hypereutec Pistons KB120-040: $463.40
Melling Oil Pump M55HV: $62.00
Misc Plugs EPC41, EPC214A, PP567T: $1.39
Victor Timing Cover Set JV881: $16.10
Parts Total: $1928.65
Labour Details/Costs for Short Block Assy:
Balance Connecting Rods
(175 Pin End, 423 Big End, Pistons and Pins, Rod Bearing, Ring Set, 1873 BW)
Disassemble Engine and Hot Tank Block and Parts
Magnaflux
Remove and Replace Cam Bearings
Bore and Hone Cylinders .040 Over
Align Hone Cyl Block/Fit Main Bearing Clearances .0025
Remove and Replace Pistons on Connecting Rods
Install New Bolts and Resize Connecting Rods
Fit Bearing Clearances .002. Torque 50PSI
Short Block Assy c/w Degree Cam
Check all Bearing Clearances Heat Tabs Installed
Grind Crankshaft .010 Rods, .010 Mains
Balance Crankshaft 1873 Bobweight
Labour Total: $1583.55
I have some other costs I haven't itemized as of yet that includes the install of the engine, the new electric fan, and misc hardware including a new battery for $1100, and the final total from the machine shop including the carb rebuild is $1193. I probably have another 2-300 in miscellaneous engine parts, so that comes to $2593 there.
Rebuild Total: $7805.69 CDN or $5308.39 US
And oh yeah, I decided to insulate under my carpet while I was working on the car. Here's some pics of that ..
Nice work,love the color :cheers: :cool:
All body mounts,
Upper/Lower front a-arm bushings.
Engine Rebuild
Install of A/R TTII rims and new tires.
86 Seats recovered and almost installed.
New door panels and other misc interior panels.
Removeable rear window.
Perma Cool electric fan.
I can't wait to stop working all this overtime and begin enjoying the car this summer. Once I have the engine done, I'll post some final pics.
