Question about insulation under the carpet.
Old Mar 31, 2003 | 10:49 AM
IRON WILL's Avatar
IRON WILL
Default Question about insulation under the carpet.
I see alot of guys are doing this on their restorations. What is the purpose for this? Does it block the heat from the exhaust that radiates through the floor and melts the soles of your shoes? I'm just curious. My car runs around 190 degrees most of the time, and I have a trans cooler. I get a rather annoying amout of heat from the exhaust through the floor. I was going to wrap the exhaust pipes with heat tape where the go under the floor. Will this insulation work also. Where do I get it from? Is it something I can get from Home Depot? Thanks.
Old Mar 31, 2003 | 11:10 AM
70454's Avatar
70454
Default Re: Question about insulation under the carpet. (IRON WILL)
I bought this insulation from Corvette America here in PA. It is a foil backed insulation sold in a kit to fit your model/year. I paid about $99 for it and I was unpleased. The insulation was pre cut and fit fairly nicely and does help prevent excess exhaust heat (especially from my big block car) from reaching the cabin. I thought it was worth $30 or $40 when I saw how cheap looking it was. Nothing against Corvette America, but it looks like another overpriced imported item.
Old Mar 31, 2003 | 11:20 AM
Edzred72's Avatar
Edzred72
Many have used a foil back insulation from home improvment stores, at a fraction of the cost. Same results as the expensive stuff bought from vendors. Just be sure it's the proper thickness or longer interior mounting bolts will be needed.
Eddie
Old Mar 31, 2003 | 11:24 AM
1LE's Avatar
1LE
You can get the foil double sided insulation on a roll from Home Depot for about $20.00 to $ 25.00. Will do the same thing that the stuff from Corvette America does. You will just have to cut it to fit.
Old Mar 31, 2003 | 12:04 PM
Mikeb690's Avatar
Mikeb690
I just did mine last weekend. I used Reflectix from Lowes it cost 25 bucks for a roll(2'X25') and 5 bucks for the heat tape. Real easy to put in and it worked great for the heat and the noise. I thought it was much better then the kits from any of the magazines and a heck of alot cheaper.
Old Mar 31, 2003 | 12:07 PM
tshort's Avatar
tshort
CI 7-8 Veteran
Default Re: Question about insulation under the carpet. (1LE)
I bought some of that stuff from Home Depot and covered the entire front area and under and behind seats. I think this will help more than just wrap on your exhaust cause it's also insulating from your under-hood heat. You might be surprised how many holes there are leaking hot air into your cabin from the firewall. I've heard to not run speaker wires right against the foil side though so I ran them between the insulation and the carpet. The stuff I bought from Home Depot had foil on one side.
Old Mar 31, 2003 | 12:13 PM
Bobchad's Avatar
Bobchad
Default Re: Question about insulation under the carpet. (Mikeb690)
Reflectix. Make sure you get the aluminum tape as well.
Old Mar 31, 2003 | 12:18 PM
fyne82's Avatar
fyne82
Huh! I was wondering the same thing about this insulation thing. Since the heater core ruined mine. I to went to Corvette America here in PA and saw the price thank god I didn't bite. I'll have to take the suggestions here to mind when I get that far to complete in mine. I wonder if you could use house hold padding as a sound deadener along with that rolled barrier?
Thanks for the info.
Old Mar 31, 2003 | 12:24 PM
Monkeywrench's Avatar
Monkeywrench
Scott did a good write up on this..
http://www.c3sharktank.com/tech2/carpet/carpet1.html
Old Mar 31, 2003 | 12:39 PM
Touringpro's Avatar
Touringpro
:iagree: Did mine last week also and was very pleased with the result. I was surprised that one roll of Reflectix was more than enough to do the whole car: front, back, even the storage compartment. Also, my initial concerns regarding the seat bolts being too short to accomodate the additional thickness the insulation provides proved unfounded - they were plenty long enough. :cheers:
Old Mar 31, 2003 | 05:52 PM
Wrecked82's Avatar
Wrecked82
Default Re: Question about insulation under the carpet. (tshort)
I noticed you have the reflective side up. I would have thought that the reflective side goes down, toward the heat source. At least that is what I did when I used the same material.
Old Mar 31, 2003 | 07:10 PM
vettfixr's Avatar
vettfixr
Go to my website for an article on my cockpit insulation install. http://mywebpages.comcast.net/vettfixr/page14.htm
Old Mar 31, 2003 | 08:55 PM
phoenix's Avatar
phoenix
Default Re: Question about insulation under the carpet. (vettfixr)
I got mine from Julianos.com
It's similar to the home depot stuff but doesn't have the bubbles. It has much more dense foam and thicker aluminum on both sides. I bought a 40 sq ft roll for $45 and it was plenty to do the entire firewall back to the rear deck.
Home depot stuff is cheaper, but if the bubbles break, you lose a lot of the insulation, (I doubt that it would happen, but for $20 I figured why do it twice) :)
BTW... it's called insul-tek
Old Mar 31, 2003 | 09:07 PM
Mikeb690's Avatar
Mikeb690
Default Re: Question about insulation under the carpet. (Larry82)
Its foil on both sides
Old Mar 31, 2003 | 09:12 PM
gdh's Avatar
gdh
I am looking at buying the VL-38 from http://www.advancedacoustical.com it is a paint on heat and sound insulation and is $50 per gallon.
Old Mar 31, 2003 | 09:16 PM
phoenix's Avatar
phoenix
Default Re: Question about insulation under the carpet. (gdh)
I used that stuff too. :)
Only problem is that it doesn't stick real well to fiberglass and doesn't stick at all to fiberglass that has the coating of oil from a leaking mechanical oil gauge. :)
I'd recommend cleaning anything you plan on coating with a wire brush, solvent and more solvent if you hope for it to stick permanently. I had the first coat peel up on the floorboards. I cleaned them all again and redid it. Hopefully 2nd time's the charm. :)
To Question about insulation under the carpet.
