650 Speed Demon question
Old Apr 6, 2003 | 05:25 PM
LFZ's Avatar
LFZ
Default 650 Speed Demon question
ok..i got the Speed Demon on the motor today..i was wondering how you guys run a throttle cable bracket to support the cable...and any suggestions on how to hook up the spring return linkage and what cable bracket to use? i'd like to still use my stock throttle cable if at all possible. thanks.
Old Apr 6, 2003 | 09:29 PM
no_radio's Avatar
no_radio
Default Re: 650 Speed Demon question (REDSHARKONBOYDS)
Yeah, this was the biggest issue I ran into when installing Demon carbs on Chevy engines.
What we wound up doing was buying a Mr Gasket or similar GM throttle cable bracket at the local parts house. This includes the square opening to capture the stock throttle cable, and has a little hole at the bottom for hooking up the stock throttle return springs.
Now, these are designed for Holleys, which have SQUARE edges on the mounting base, the Demons are ROUND. So we took a small drill bit and drilled a hole in the bracket and the carb base to allow a roll pin to be tapped in. This prevents rotation, and the bracket is held in place vertically by the carb mounting stud.
Don't have a picture handy, but this worked on my '74 Corvette (small block) and my '76 Suburban (454) both with Speed Demons.
Yes, I know it sucks to drill a hole in a brand new $400 carb, but it's the only way I've done it. I hear you can buy a bracket from Edelbrock that mounts to their intakes...never did it.
Jeff
Old Apr 6, 2003 | 09:39 PM
LFZ's Avatar
LFZ
Default Re: 650 Speed Demon question (no_radio)
jeff, i think i'll go with your idea....btw, how do you like your Speed Demon?? have any tuning problems or any noticable differences in performance?
Old Apr 6, 2003 | 11:04 PM
tshort's Avatar
tshort
CI 7-8 Veteran
I use a lokar cable and CSI bracket. They also make a Holley bracket just like it from Jegs. At least I think it's a Holley?
Old Apr 6, 2003 | 11:22 PM
Aaron-74's Avatar
Aaron-74
LOL..Yeah, Jeff really didn't want to drill a hole in the base of his carb. But, it was the only Idea I had. We even tried welding some funky bracket together. But that didn't work. But, the dowel in the base worked like a charm.
That's probably the least expensive way to go about it.
-Aaron.
Old Apr 7, 2003 | 06:08 AM
Mystery Machine's Avatar
Mystery Machine
Default Re: 650 Speed Demon question (tshort)
I had to drill too. Not fun but it works.
tshort, your setup is very cool looking. :thumbs:
Old Apr 7, 2003 | 06:11 AM
1979toy's Avatar
1979toy
The Edelbrock bracket is MUCH stronger than the Mr. Gasket piece and well worth the time required to hunt one down.
Old Apr 7, 2003 | 07:51 AM
Paul 75 L82's Avatar
Paul 75 L82
Default Re: 650 Speed Demon question (1979toy)
The Edelbrock bracket bolts to the last 2 manifold bolts, no drilling required. I did have to do some modifaction on the bracket but not the carb. I just hooked the spring on the bracket.
Old Apr 7, 2003 | 11:22 AM
LFZ's Avatar
LFZ
Default Re: 650 Speed Demon question (Paul 75 L82)
Paul, can you give me the part# for that edelbrock bracket?? i have vortec heads too, so its got kinda of a different manifold set up with the bolts....think it will still work? thanks
Old Apr 7, 2003 | 01:20 PM
no_radio's Avatar
no_radio
I love it! My old QJet was never right, even after I had it "professionally" rebuilt. Immediately, I noticed increased throttle response, and the higher RPMs flew by a lot faster as well. Haven't done much tuning on it, yet, but bought a full jet kit a couple weeks ago and hope to get to some tuning this weekend.
I liked the 650 so much I bought a 750 vacuum secondary for my Suburban. Same deal, QJet was getting old (30K since rebuild) and was acting up. Instantly ran better, and idles better than it ever has. I shaved two full seconds off my 0-60 (vs QJet running crappy, it used to be faster). Haven't driven it enough to check fuel mileage, hoping to gain an MPG or two. Also haven't tuned this one, except to change the secondary spring, which takes about 2 minutes and took the last .4 seconds off my best 0-60.
I think you'll be happy.
One quick note...in the instructions I read BG talks about having both front and rear butterflies open equally. This is typically only true if your engine idles above 1000 RPM. I had both open and was WAY too rich at first. Closed rears, nice idle now. ALso, their tech line has been really helpful, don't be shy about calling with questions.
Jeff
To 650 Speed Demon question
