700R4 Yoke question..
Old Apr 6, 2003 | 10:37 PM
Budman68's Avatar
Budman68
Cruise-In VII Veteran
St. Jude Donor '07
Default 700R4 Yoke question..
Well the 350 yoke is way to lose for my liking, so I am in shearch of a 700R4 yoke with bolt on u-joints. Any clue what car those came on?
Old Apr 6, 2003 | 11:52 PM
redvetracr's Avatar
redvetracr
Default Re: 700R4 Yoke question.. (Budman78)
Budman,
I have a brand new one if your interested, small (27 spline) to the big u-joint (Corvette type bolt on straps). ...redvetracr
Old Apr 7, 2003 | 02:24 PM
Budman68's Avatar
Budman68
St. Jude Donor '07
Default Re: 700R4 Yoke question.. (redvetracr)
Turns out, someone was right. The rear trans bushing is wore out. You would have thought the transmission shop would have replaced it. yep e the 350 yoke will work.
Old Apr 7, 2003 | 03:43 PM
PatsLs1vette's Avatar
PatsLs1vette
im using the 350 yoke so i knew it worked. :D
Old Apr 7, 2003 | 05:25 PM
TedH's Avatar
TedH
I tried using my TH350 slip yoke. Had leaks. Found that the shop that shortened the driveshaft must have machined too much off of the yoke to clean it up (had some surface rust from sitting on the floor). Purchased a new slip yoke from Bow-Tie Overdrives for approx $79. No more leak.
To 700R4 Yoke question..
