---Ram Jet ZL1 crate engine!!!---
Old Apr 7, 2003 | 03:57 PM
Cookwithvette's Avatar
Cookwithvette
Default ---Ram Jet ZL1 crate engine!!!---
New Pace catalog came today. While flipping through I found this little jem. Price not listed on the website but catalog lists it at $21,454.00. Okay, with a price like that it's not really much more than a dream... still neat to look at though.
From Pace website: (http://www.paceparts.com/product.asp?3=56150)
Ram Jet ZL1: Part number not yet available
Getting a hold of one of these may be more difficult than hitting your state lottery. GM Performance Parts is proud to bring back a legend, if only for a limited time. The Ram Jet ZL1 is the ’69 ZL1 of the new millennium, with its revised aluminum block, a solid roller cam, large oval port aluminum cylinder heads, and the Ram Jet fuel injection system...that’s right, Fuel Injection. The Ram Jet ZL1 is ‘454 cid with a street friendly 10.2:1 compression ratio that will idle all day long, unlike its predecessor of the late 60’s. If you want a Ram Jet ZL1 get in line now, GM Performance Parts will be producing a very limited 200 of these all-aluminum Rat Motors for sale on the open market and I would be willing to bet Jay Leno already has his eye on one...make that 199!
Ram Jet ZL1 Technical Information
·HP: 510 @ 5750
·Torque: 493 Ft. Lbs. @ 4250 RPM
·Compression Ratio: 10.2:1
·Bore: 4.250”
·Stroke: 4.00”
·Block: Mark IV Aluminum ZL1
·Crankshaft: Forged 1053 Steel
·Connecting Rods: Forged 4340 Steel
·Pistons: Forged aluminum with pressed pin
·Piston Rings: Plasma-moly rings
·Camshaft: Mechanical roller
(.640” / .598” lift)
(236 / 232 duration @ .050”)
·Lifters: Mechanical Roller tappet
·Cylinder Heads: Aluminum Oval Port with a 110cc combustion chamber
·Intake Valves: 2.25” Stainless Steel
·Exhaust Valves: 1.88” Stainless Steel
·Rocker Arms: Aluminum Roller Rockers, 1.7:1 ratio
·Push Rods: High Performance (1-piece)
·Intake Manifold: Ram Jet Injection (complete with wiring harness and CPU)
·Windage Tray: All new design, Teflon coated
·Damper: GM 8”, counterweighted
·Distributor: Electronic CPU controlled
·Ignition Timing: Base 10-degree
·Spark Plugs: R43XLS
·Fuel: 92 Octane
[Modified by Cookwithvette, 9:04 PM 4/7/2003]
Old Apr 7, 2003 | 04:01 PM
Metal Wulf's Avatar
Metal Wulf
Default Re: ---Ram Jet ZL1 crate engine!!!--- (Cookwithvette)
:eek:
Old Apr 7, 2003 | 04:06 PM
Merlin522's Avatar
Merlin522
Now they need to offer it as an option in the C6!!!!!!!!!!!
e3pres's Avatar
e3pres
St. Jude Donor '08-'09
:cool: :eek:
Old Apr 7, 2003 | 04:07 PM
bence13_33's Avatar
bence13_33
Those horsepower and torque numbers are horrible. That motor is a mess for $22,000. That motor is begging for 11-12:1 compression, some really nice flowing R-Port heads and a bigger camshaft.
Old Apr 7, 2003 | 04:27 PM
Brettmc's Avatar
Brettmc
I agree with bence. For 22k, I better get a lot more than 510 hp!! The catalog says one can buy the bare alum block for a mere $5k!! Whew!! I think I'll stick with iron.
Brett :thumbs:
StarLord's Avatar
StarLord
I don't see it's weight listed in the specs. Or is that not a factor with engines? Isn't lighter=better?
Old Apr 7, 2003 | 04:37 PM
ZD75blue's Avatar
ZD75blue
In hotrod they were talkin about this one awhile back, the big deal is that it can idle in traffic, and gets 20mpg on the road... while still being a monster :cool:
Old Apr 7, 2003 | 04:39 PM
Ryan77's Avatar
Ryan77
Default Re: ---Ram Jet ZL1 crate engine!!!--- (StarLord)
That's $43 per horsepower :eek: . You can build a streetable 383 with the same horsepower and more torque for about $6k. AFR has dyno sheets for this on the website: http://www.airflowresearch.com then click on "dyno tests" at the top of the page :cheers:
[Modified by Ryan77, 4:40 PM 4/7/2003]
Old Apr 7, 2003 | 04:43 PM
Cookwithvette
Weight is very important. Not sure the weight of the fully assem. ZL1 but bare block is 110# Vs. cast iron bare block 270#.
I would guesstimate the fully assembled engine weighs around 300#.
Aluminum small block (bare) weighs only 90 pounds. That would be my choice for aluminum.
Old Apr 7, 2003 | 04:50 PM
bence13_33's Avatar
bence13_33
Default Re: ---Ram Jet ZL1 crate engine!!!--- (ZD75blue)
ZD75blue:
Point taken. However if I recall Chuck Harmon is getting like 16-18MPG on the highway with his ROD 6 speed. That's with a high compression, solid flat tappet carbureted big block.
I suppose 20MPG is an accomplishment. However I didn't build my car to be an economical machine. My motor is putting out very close numbers to that motor but costs $17,000 less :) and weighs a little bit more. I can fill my gas tank up a heck of a lot of times with $17,000.
I guess I'm just disappointed with what could have been a re-release of a monster.
Old Apr 7, 2003 | 05:02 PM
B's Avatar
B
thats one bad motor but the price is :crazy: you could buy a used c5 for almost that much.
Old Apr 7, 2003 | 05:07 PM
Crickett's Avatar
Crickett
Dayum!!!!!! :eek: :cool:
Old Apr 7, 2003 | 05:28 PM
garagedweller2's Avatar
garagedweller2
Default Re: ---Ram Jet ZL1 crate engine!!!--- (Crickett)
I want it!!!! In 427, carb'd, ZL1 cam, dry sump lube, Brodix heads. Time to go hot-lapping! I think my dream engine is cheaper too!
Old Apr 7, 2003 | 05:31 PM
Cali,68,L-79's Avatar
Cali,68,L-79
Default Re: ---Ram Jet ZL1 crate engine!!!--- (garagedweller2)
I'll take it if they insist.
Old Apr 7, 2003 | 05:35 PM
81vette's Avatar
81vette
Your not paying for horsepower......your paying for a serial number.
mark
Old Apr 7, 2003 | 05:55 PM
QuickVet's Avatar
QuickVet
That is sweet. but even if i had that kind of money, no way would i pay 21K for 500HP :rolleyes:
To ---Ram Jet ZL1 crate engine!!!---
Old Apr 7, 2003 | 06:16 PM
NHvette's Avatar
NHvette
Default Re: ---Ram Jet ZL1 crate engine!!!--- (81vette)
mark
:iagree: Exactly. It'll take a LONG time for that motor to ever be worth more
than $20k. Even if you can afford to buy a ZL-1 Camaro to put it in - it's still
not original. This is the only good reason I can think of to buy one.
Oh well - there's got to be at least 200 people around with that much cash to drop on a 500HP BB - so they should sell 'em OK.
Old Apr 7, 2003 | 06:33 PM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
Default Re: ---Ram Jet ZL1 crate engine!!!--- (NHvette)
They`re not gonna sell one to me for that price but it sure would be nice to have something like that out front.
Old Apr 8, 2003 | 01:04 AM
Cookwithvette
200X$21,454....
$4,290,800
Four and a quarter+ million dollars on 200 engines. Maybe I should consider buying GM stock. :crazy:
