Questions about 79' L48
Old Apr 8, 2003 | 07:41 PM
kwik8racr's Avatar
kwik8racr
Default Questions about 79' L48
Need some help here guys, I am a C5 guy, but have a friend that just purchased a 79' with the L48, and he is wanting to know the specs on the motor. Can anyone direct me to where I might find the specs? Thanks! :cheers:
Old Apr 8, 2003 | 08:13 PM
79corvette's Avatar
79corvette
Default Re: Questions about 79' L48 (kwik8racr)
As far as an off-line refrence the Chilton's repair manual for them have some specs. Mine states that for a 79 it has: 195hp@4000 torque: 285@3200 bore and stroke 4.000 x 3.480 compression ratio: 8.2 : 1
If that's what you mean by specs, I'm sure others will have online refrence material.
Old Apr 8, 2003 | 08:22 PM
kwik8racr's Avatar
kwik8racr
Default Re: Questions about 79' L48 (79corvette)
Yes, that is what I am looking for! Got any cam specs? He is wanting to replace the cam, any recomendations?
Thank you!! :cheers:
Old Apr 8, 2003 | 09:04 PM
Ganey's Avatar
Ganey
Stock is very mild!
Sure. What's trans. & rear gears, needed for cam.
Old Apr 8, 2003 | 10:06 PM
timbo79's Avatar
timbo79
Default Re: Questions about 79' L48 (Ganey)
See the following
1979 Corvette.dyn Dyno2000 Version 3.10 Page 1 of 5
Chevy 350 4.030 in 3.480 in
8 727.41 cc 355.1 ci
Low Performance/Ported, Large Valves
1 1
1.914 in 1.650 in
9.50 85.58 cc
795.0 cfm 1.50 inHg Gasoline
Dual-Plane Manifold 0.0 lbs/min
Large-Tube Headers With Mufflers
270H 270H.cam
Hyd.
Seat-To-Seat
0.500 in
0.500 in
29.0 61.0
69.0 21.0
-10.0
106.0
110.0
270.0
270.0
50.0
SHORT BLOCK
1979 Corvette.dyn Dyno2000 Version 3.10 Page 2 of 5
CYLINDER HEAD AIRFLOW DATA
Description: Low Performance/Ported, Large Valves
Intake Valve Exhaust Valve
Test Diameter: 2.020 in
Pressure Drop: 25.0 inH2O
Test Diameter: 1.600 in
1979 Corvette.dyn Dyno2000 Version 3.10 Page 3 of 5
CALCULATED POWER AND ENGINE PRESSURES
Corvette.dyn Dyno2000 Version 3.10 Page 4 of 5
Power (HP)-1979 Corvette.dyn Torque (ft-lbs)-1979 Corvette.dyn
I hpe this came out ok
Desktop dyno will d0o the trick I am running .30 over with 3.55 rear, and a Comp Cam 270H CAM
Old Apr 8, 2003 | 11:11 PM
wbarkley's Avatar
wbarkley
I guess your question has already been answered, but if you need more info on the '79, head on over to the registry. While you're there, why not sign up?
http://www.vettefinders.com/79regist...ications01.htm
Old Apr 8, 2003 | 11:14 PM
kwik8racr's Avatar
kwik8racr
Default Re: Questions about 79' L48 (wbarkley)
Thanks for all the info guys! :cheers:
Old Apr 9, 2003 | 08:47 AM
groovyjay's Avatar
groovyjay
Also make sur you'll join in for the 79Registry:
http://www.vettefinders.com/79registry/front.htm
Congrats on the new car! :cheers: :steering:
To Questions about 79' L48
