1968 Rocker Moulding ??
Old Apr 8, 2003 | 10:30 PM
Cole Neadow's Avatar
Cole Neadow
Default 1968 Rocker Moulding ??
Can someone tell me what holds the rocker mouldings in place on an early 68? Mine has large flat head screws along it, is this correct or has Bubba been at work ? :rolleyes:
Thanks Cole
Old Apr 8, 2003 | 11:21 PM
sb69coupe's Avatar
sb69coupe
Default Re: 1968 Rocker Moulding ?? (Cole Neadow)
Which piece, the upper thin strip or the lower fiberglass piece?
Old Apr 9, 2003 | 12:31 AM
Cole Neadow
Default Re: 1968 Rocker Moulding ?? (sb69coupe)
I,m not sure just where the screws are I will check in the morning
Thanks Cole
Old Apr 9, 2003 | 02:16 AM
GDaina's Avatar
GDaina
you can get the correct mounting screws from all the major corvette vendors
[Modified by GDaina, 2:17 AM 4/9/2003]
Old Apr 9, 2003 | 12:20 PM
PRNDL's Avatar
PRNDL
".... attached to the body with seven black-oxide, cross-recess oval-head screws." If you are at all interested in factory correct appearance and equipment you should get a copy of the NCRS Technical Information Manual and Judging Guide for your model year (68-69). MJ
Old Apr 9, 2003 | 03:00 PM
Cole Neadow
Default Re: (MNJack)
Thanks, I see Bubba must have been around, mine are hudge flat heads. My car is in the paint shop right now, so I will order the correct screws and fix holes as required.
Thanks Cole
To 1968 Rocker Moulding ??
