Bolt pattern and Back Spacing Question
Old Apr 9, 2003 | 12:03 PM
conway62's Avatar
conway62
Default Bolt pattern and Back Spacing Question
I want to purchase a set of Cragar rims for my 71. Could anyone tell me the proper backspacing and mounting diameter? I think it is a 5" bolt patten with 4" Backspacing but I want to be sure before ordering the wheels.
Thanks in advance
:steering:
Old Apr 9, 2003 | 01:29 PM
vettery's Avatar
vettery
Default Re: Bolt pattern and Back Spacing Question (conway62)
The bolt circle diameter is 4-3/4". The 4" backspacing is correct I belive for an 8" wide wheel. There are those who use as much as 5" BS with wider wheels but some modifications are required. If the wheel you want requires a spacer to clear the brake calipers, then you can add the thickness of the spacer to the 4 inches to determine the backspacing for the new wheel.
