Synthetic Oil Question
Old Apr 9, 2003 | 12:04 PM
Corz's Avatar
Corz
Cruise-In IV Veteran
Default Synthetic Oil Question
So I've come to the task of throwing new oil in my car. but I'm not sure if anything is broken internally (see how to kill a shark). I was running royal purple synthetic blend oil. I'm broke and i have about 3 gallons of unused regular motor oil. Is it ok to throw regular oil in the car to see if there is any damage to the engine? keep in mind i lost over 2 quarts of oil on my ride home.. I drained all the synthetic out, put a new filter in and I'm ready to go.
Is it ok to swap this for just a couple minutes of run time to check my engine ?
Old Apr 9, 2003 | 12:22 PM
Madmikeee's Avatar
Madmikeee
From: Sometimes I wonder... why is that frisbee getting bigger? Then it hits me.
Cruise-In X Veteran
St. Jude Donor '06
Default Re: Synthetic Oil Question (Corzvette69)
Hey cor, I heard that swapping oils like that could play havoc with your seals/gaskets.. that is only what I HEARD.. I have never run synth oils so I am no expert.
:cheers:
Old Apr 9, 2003 | 12:39 PM
no_radio's Avatar
no_radio
Default Re: Synthetic Oil Question (Madmikeee)
Oil is oil...if it's the correct viscosity and API rating then you can use it, no problem.
Old Apr 9, 2003 | 12:44 PM
Corz's Avatar
Corz
Default Re: Synthetic Oil Question (no_radio)
sweet, thanks
To Synthetic Oil Question
