Help vacuum doors won't close
Old Apr 9, 2003 | 08:15 PM
1971454ILvette's Avatar
1971454ILvette
Default Help vacuum doors won't close
What makes the headlights and the wiper doors close. I started the engine and they both popped open on their own, and now they won't close. Thanks
Jay
:banghead:
Old Apr 9, 2003 | 08:36 PM
joe73vette's Avatar
joe73vette
Default Re: Help vacuum doors won't close (1971454ILvette)
See if the ***** under the steering column have been pulled down. Otherwise there is a hose loose. Joe
Old Apr 9, 2003 | 10:35 PM
74 vert's Avatar
74 vert
From: Where are the Smoky Mountain Cruisers? Not Correctly Restored Stingray
Default Re: Help vacuum doors won't close (joe73vette)
I had this problem after I installed a new headlight switch. I ended up hearing a leaking hose around the switch. After I tighted the hose at the connection everything worked. The only PITA was needing to partially remove the lower driver dash.
To Help vacuum doors won't close
