Carb Jetting for 69
Old Apr 10, 2003 | 09:10 AM
69Sting's Avatar
69Sting
Default Carb Jetting for 69
First thing I would like to say is that this forum is great. I have only had my vette for a little over a year and it was a purchase/inheritance so I know very little to nothing about vettes. After reading many of these forums I have learned more in a few hours then I have just tinkering on the car.
I am still figuring out the set up of my 69 Stingray convertable. I beleive what I have is a combination of the Z03 trany and rear gears with the L46 motor. :crazy:
When I received the car the intake and carb have been changed to a Holey 600 vacum secondaries and a Edelbroke intake.
I have not come accross a Holley 650 manual secondaries. What jets are best to put in this carb for the L46 motor? I know very little about carbs so any additional help is welcomed.
On top of this I have looked into an MSDS system but the cash is not looking good to do this yet. I see all sorts of Distributer cap w/ Super coils that are to give a higher spark/more power, do these help or just gimicks?
:cheers:
Old Apr 10, 2003 | 11:58 AM
clem zahrobsky's Avatar
clem zahrobsky
Cruise-In I Veteran
Cruise-In II Veteran
Default Re: Carb Jetting for 69 (69Sting)
post the "LIST#" that is on the front of the choke housing and i will try and help you out.
:cheers:
:chevy
Old Apr 10, 2003 | 06:07 PM
69Sting's Avatar
69Sting
Default Re: Carb Jetting for 69 (clem zahrobsky)
It is a Holley 650 Double pump list # 6210-1 Also 3504 was above it.
Hope this helps.
Old Apr 10, 2003 | 06:42 PM
clem zahrobsky
Cruise-In I Veteran
6210-1 holley 650 cfm,pri jet 60/2, sec jet 63/2, pri power valve #85, sec power valve #65, pri squirter .025, sec squirter .037. that should be a good starting point :chevy
Old Apr 10, 2003 | 07:05 PM
Robert N's Avatar
Robert N
Start with the original configuration listed above. Then step us 2 jet sizes at a time to fine tune. I am running a 650 DP and am using 71 primary jets. 69s did not provide enough fuel in my application.
Old Apr 10, 2003 | 08:41 PM
69Sting's Avatar
69Sting
Default Re: Carb Jetting for 69 (Robert N)
I will start off as suggested.
Unfortunatly in WI we just had some snow so the roads are full of salt yet. :mad
It will be a couple weeks before I can get the new carb on.
I will keep you posted.
thanks again
Old Apr 10, 2003 | 08:51 PM
clem zahrobsky
Cruise-In I Veteran
with a small CFM carb the air flow thru the carb is the limit the carb will flow no matter what size engine it is on and any time you need more than + 2 sizes on the jets from stock i would be suspect of the fuel supply. :chevy
Old Apr 11, 2003 | 11:36 AM
69Sting's Avatar
69Sting
Am I doing a good thing by going to the Holly 650 and keeping the Edelbrook intake or should I go to the original intake and Quadrojet carb?
Looking for best perfomance and power.. I do have the originals..
Old Apr 11, 2003 | 06:28 PM
clem zahrobsky
Cruise-In I Veteran
the Q jet is a 750 cfm carb so i would try the edelbrock manifold with the q jet :chevy
To Carb Jetting for 69
