Backup / Reverse Lights switch - Question
Old Apr 10, 2003 | 10:30 AM
TwoVetteJack's Avatar
TwoVetteJack
Default Backup / Reverse Lights switch - Question
Has anyone installed a switch on the transmission that controls the backup lights? Can you tell me where to start? I've ordered and received the part and I'll be going under the car this weekend. Any tips would be greatly appreciated. :flag
Old Apr 10, 2003 | 10:40 AM
Corvettelvr73's Avatar
Corvettelvr73
Default Re: Backup / Reverse Lights switch - Question (TwoVetteJack)
Where did you order the parts from and what are the part #'s? How much did it cost you?
Old Apr 10, 2003 | 10:53 AM
TwoVetteJack
Default Re: Backup / Reverse Lights switch - Question (Corvettelvr73)
http://www.corvettecorner.com/Catalo...20%20Parts.htm
About $55
6556 68-78 Back-Up Lamp Switch w/Manual Transmission....................... 53.55
Check it out! :flag
Old Apr 10, 2003 | 11:09 AM
sb69coupe's Avatar
sb69coupe
The switch is mounted on a bracket which attaches vto the transmission case via two of the side cover bolts. The "lever" on the switch connects to the reverse gear lever on the transmission with a small rod. When the transmission is put into reverse, the reverse gear lever pivots and thereby throws the backup light switch lever to close the circuit and complete the connection, delivering +12v through the switch and on to the reverse lights. The pigtail from the wiring harness which connects to the wiring for the backup light switch comes through the firewall down between the master cylinder area and the transmission tunnel. It's a two wire connector with a pink and a green (if memory serves) wire.
Do you have the small rod and clips needed to connect the switch to the reverse gear lever?
Old Apr 10, 2003 | 01:11 PM
Wrencher's Avatar
Wrencher
Default Re: Backup / Reverse Lights switch - Question (sb69coupe)
My switch was still attached to the trans when I got it, but had to make the rode and scrounge up a clip...
Hans
Old Apr 10, 2003 | 02:10 PM
69Sting's Avatar
69Sting
Default Re: Backup / Reverse Lights switch - Question (Wrencher)
That switch is over rated. When I pulled my trany out last summer to put in a centerforce Dual friction clutch, :cool: I had the switch installed backwards so my back up lights only went on going forward. I just took the switch off. It isn't like you get a lot of light back there anyway.
Look behind you before you back up and stick your head out the window. Works better. :cheers:
Old Apr 10, 2003 | 02:18 PM
rreavis's Avatar
rreavis
Let us know how hard it was to replace. I would like to replace mine too. Backup lights quit working about 2000 forward miles ago but they are needed to pass inspection, which is due. Arghhh :smash:
Old Apr 10, 2003 | 06:11 PM
My69's Avatar
My69
TwoVette:
Do what sb69coupe said. I did mine, the hardest part was getting my butt under the car. Should take all of 15 minutes
Mike :auto:
To Backup / Reverse Lights switch - Question
