Hello All!! Just signed on.
Old Apr 10, 2003 | 01:06 PM
Harv69's Avatar
Harv69
Default Hello All!! Just signed on.
This is my first post, and I bought my first Corvette last week.
Its a 1981 t-top (I will try to load picture). The car has 56,000 miles on her and has been well taken care of (my brother owned it previously).
Anyway it has only 2000 miles put on it in the last ten years , so it has a few things wrong with it , mostly stuff associated with the car sitting so much.
Noticed that the brake pedal was spongy and the front left caliper was leaking a little fluid , so I removed the caliper , honed out the cylinders ,put in a new seal kit, replaced the master cylinder and gravity bled all four wheels. This seemed to help a little but the pedal is still spongy and the brake warning light on the dash still comes on. Anyone have any ideas?
Old Apr 10, 2003 | 01:16 PM
BB wowbagger's Avatar
BB wowbagger
Default Re: Hello All!! Just signed on. (Harv69)
Welcom to the Shark Pond...Hope you brung your wallet :jester :cheers: :cheers:
If the pedal is still "spongy" theres some air left in the system.C3s are a bear to bleed.. :smash: :smash:
Old Apr 10, 2003 | 01:17 PM
TJRed76's Avatar
TJRed76
Welcome to the forum!
I would keep checking for other leaks. I know that on my 76, the hoses were bad and leaked. When I replaced the callipers, I thought that the problem was solved. There was so much crud around the hoses, that it was not dripping or seeping onto the driveway. I didn't know they were leaking untill I went to searching for more trouble.
Good luck, and be ready for the fact that you will never be done tinkering with your new toy.
Enjoy the Addiction, it's great! And you have come to the right place for information. The people on this forum have such a wealth of knowledge that you will be amazed.
TJRed76 :cheers:
HDIronman's Avatar
HDIronman
You're gonna like it here. Welcome !!!! :cool:
Old Apr 10, 2003 | 01:18 PM
Gordonm's Avatar
Gordonm
Most C3 brake systems after 20+ years will need a rebuild. New Stainless Steel sleeved calipers are the only way to go. Get a NEW master cylinder and check to make sure the rotors have enough meat left on them. When all this is replaced you will have a safe braking car.
Old Apr 10, 2003 | 01:29 PM
IETEK
Not to discourage you, I ended up replacing the master cylinder 3 calipers and the two front brake lines. My car had set up for about five years before I bought it.
Before I bought anything else I would try to bleed the brakes again it has been my experience that it is hard to get all of the air out unless you vacum bleed the lines.
Just a word of warning if you do spring a leak while driving you will have very little brakes if any. Been there done that!
Good luck, IETEK :cool:
Old Apr 10, 2003 | 01:30 PM
72GACRZR's Avatar
72GACRZR
:seeya welcome to the pond. Lot's of help here. If you do a search in the archives, you will find more than you want to read on brakes. The light in the dash, is used for parking brake on, low fluid in master clyinder and the proportioning valve, if the caliper was leaking, then it would slide to put more stopping power on the rear, you have to reset them sometimes. This is covered in the archives also.
Old Apr 10, 2003 | 01:49 PM
Alwyn678's Avatar
Alwyn678
Default Re: Hello All!! Just signed on. (BB wowbagger)
:seeya :seeya We will help you spend your last DIME :cheers:
[Modified by Alwyn678, 1:49 PM 4/10/2003]
Old Apr 10, 2003 | 02:09 PM
rreavis's Avatar
rreavis
Welcome and glad you're here. These guys know what they are talking about so all you have to do is listen and crack open that wallet.. Had to replace all 4 callipers with SS and while I was at it, put on SS hoses too... It is just money, you will make more.... :flag
Old Apr 10, 2003 | 02:14 PM
Edzred72's Avatar
Edzred72
Default Re: Hello All!! Just signed on. (Alwyn678)
:iagree: :iagree: Someone send him a Summit and Jegs catalog...quick!! :lol: :lol:
Welcome..... :seeya :seeya :seeya
Eddie
Scott78's Avatar
Scott78
Default Re: Hello All!! Just signed on. (rreavis)
Welcome, you'll need a helper but check the hoses to make sure they aren't "bulging" as pressure is applied. Or alternatively just figure on going thru all the calipers and hoses, as if one caliper has gone bad the others probably are in nearly the same condition.
Old Apr 10, 2003 | 02:15 PM
75Rag's Avatar
75Rag
Welcome ....... considering you can't stop, it's a great start :lol:
My baby sat for a long period too. I ended up changing all 4 calipers and the master cylinder. A little nasty on the bleed but had some friends to help out.
Good luck
Old Apr 10, 2003 | 02:45 PM
Metal Wulf's Avatar
Metal Wulf
Default Re: Hello All!! Just signed on. (TJRed76)
:seeya
Old Apr 10, 2003 | 02:57 PM
SnoDrgn's Avatar
SnoDrgn
From: Swords Check/Saws Check/Clubs Check/Claws Check/Hatred Check/Anger Check/Murmaid Check/Murder Check
Cruise-In IV Veteran
Cruise-In VI Veteran
:seeya Had the same thing happen with mine. Replaced all the calipers with ones with SS sleeves. The first year it was just two and the problem was fixed for 6-8 months. Then last year I pulled it out and the problem returned so I has the other two replaced. I had enough wear to let air in but had little to no seapage. I could bleed the brakes and it was all good until the next hard stop. Mine sat for a couple of years outside neglected before I brought it home :yesnod:
[Modified by SnoDrgn, 1:57 PM 4/10/2003]
Old Apr 10, 2003 | 03:02 PM
TedH's Avatar
TedH
Be doubly sure you are bleeding Front and Rear calipers in proper sequence. Front has two bleeders (one per caliper) so Left front, then Right Front.
Rear is a little more tricky. Left Rear inner, Left Rear Outer, Right Rear Inner, Right Rear Outer.
Old Apr 10, 2003 | 03:04 PM
norvalwilhelm's Avatar
norvalwilhelm
Welcome to the forum Scott. This is a great place to learn about corvettes and how to fix them.
Welcome :) :) :)
Old Apr 10, 2003 | 04:33 PM
Avette4me's Avatar
Avette4me
Cruise-In VIII Veteran
:seeya Welcome. Alwyn's right, prepare to become pennyless
To Hello All!! Just signed on.
Old Apr 10, 2003 | 05:05 PM
burners's Avatar
burners
Cruise-In V Veteran
Greetings. We are glad to have you here. Overall it sounds like you have a pretty nice car. I second TedH's suggestion about bleeding the rear calipers. It would probably be a good idea to change the seals on all the calipers. Were they stainless steel sleeved or just stock cast iron?
Old Apr 10, 2003 | 05:10 PM
My69's Avatar
My69
Welcome aboard! You have just aquired an expensive habit.
Mike :party:
Old Apr 10, 2003 | 05:20 PM
BlueL36's Avatar
BlueL36
Cruise-In V Veteran
Hiya Harv69 :seeya You can use the search function over <-- there to find out about all kinds of stuff, too.
