Stock sb400 strength?
Old Apr 10, 2003 | 05:53 PM
inqbus383's Avatar
inqbus383
Default Stock sb400 strength?
I posted this over in engine mods, and since I'm going to be tearing the engine down, I'd appreciate any advice from you guys about stock 2bolt sb400 parts(crank, rods, pistons) necessary to support 500hp/torque and 6500rpms. Thanks!
http://forums.corvetteforum.com/zerothread?id=535130
Old Apr 10, 2003 | 08:27 PM
The Money Pit's Avatar
The Money Pit
Default Re: Stock sb400 strength? (inqbus383)
I run a 4 bolt,but I hear 2 bolts are said to be even stronger in the web area.
The stock pistons were cast,and aren't worth a hill of beans for power.
The assembly I got was a Scat Series 9000 crank,5.7" Scat rods,TRW flattops,rings,bearings,flexplate and balancer.All balanced for under a grand.
I can tell you there's no vibration from the engine,even at 6500 rpms,smooth as can be,and I am pushing 500hp easy.
Old Apr 10, 2003 | 10:32 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
Default Re: Stock sb400 strength? (The Money Pit)
If you want 500 HP a forgerd crank and forged rods are a good bet but if you want to save money you can go the Scat 9000 route, I would not put anyting less in a 406 :D
Old Apr 10, 2003 | 11:37 PM
boredsoIstrokedit's Avatar
boredsoIstrokedit
:withstupid:
Old Apr 11, 2003 | 09:01 AM
The Money Pit
Default Re: Stock sb400 strength? (boredsoIstrokedit)
The guy I baught my block from had 3 other 400 blocks sitting on the garage floor next to his race Camero.He turns 7200 rpms at the track and runs nothing but Scat 9000 cranks. Never has had a problem.
To Stock sb400 strength?
