Should I cut a coil off a #550 spring?
Old Apr 11, 2003 | 10:11 AM
Scooter70's Avatar
Scooter70
Default Re: Should I cut a coil off a #550 spring? (Corzvette69)
Corey,
How much did you cut off? 1/2? 3/4? I'm at about 29" right now and I'd like to get to 27 or so. The front end of my car is pretty light compared to some....small block, no power steering, no power brakes, no A/C.
Old Apr 11, 2003 | 01:47 PM
BSeery's Avatar
BSeery
From: Exiled to Richmond, VA - Finally sold my house in Murfreesboro, TN ?? Corner of "Bumf*&k and 'You've got a purdy mouth'."
CI 6-7-8 Veteran
CI-VIII Burnout Champ
St. Jude Donor '06-'10, '13
Default Re: Should I cut a coil off a #550 spring? (1bad69)
i'd heat it over cutting it..
NO !
Heating the spring steel changes the properties of the metal and a: ruins the spring rate and b: can cause it to break and colapse while driving.
And if you cut a coil, use a cut off wheel and not a torch. A torch takes too long and heats the metal too much.
Old Apr 11, 2003 | 01:50 PM
BSeery's Avatar
BSeery
CI 6-7-8 Veteran
Default Re: Should I cut a coil off a #550 spring? (Scooter70)
Corey,
I have the VBP 460's in the front. I cut about 1 and 1/4 coil. I have SBC with air, power steering and all options. However I do have aluminum heads, intake and water pump. Right now I have a fender height at about 26 - 26.25 inches. It's just a bit too low for street driving. I would shoot for 26.5 as the lowest.
Old Apr 11, 2003 | 05:04 PM
Corz's Avatar
Corz
Cruise-In IV Veteran
Default Re: Should I cut a coil off a #550 spring? (BSeery)
Corey,
I cut off 1 coil. and I'm at 27.75" up front. small block, power steering, iron heads yanked my ac out :thumbs:
Old Apr 11, 2003 | 05:39 PM
Jughead's Avatar
Jughead
Senior Member since 1492
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
I Right now I have a fender height at about 26 - 26.25 inches. It's just a bit too low for street driving. I would shoot for 26.5 as the lowest.
:iagree: I'm at 26.5 inches now and occassionally scrape the rear exhaust clamp next to the differential. Here's a pic right after I cut. It's settled a little more now though.
Old Apr 11, 2003 | 06:00 PM
Corey_68's Avatar
Corey_68
Default Re: Should I cut a coil off a #550 spring? (1970 Stingray)
I just came back from the shop. The car sits at 28 1/4 from ground to lip. The is with NONE og the following: radiator (aluminum), no water in the rad, no oil, carb, shocks, and hood. You think with the parts about it would drop another 1/2-1 in?? :confused:
[Modified by Corey 68, 6:15 PM 4/11/2003]
Old Apr 11, 2003 | 07:10 PM
no_radio's Avatar
no_radio
Default Re: Should I cut a coil off a #550 spring? (Corey 68)
It will definitely drop at least 1/2". The rad and hood alone are pretty heavy aluminum or fiberglass, but still heavy. I would recommend re-assembling the car and putting a few miles on it. I just put 550# coils in my '74 (SB, aluminum heads, intake, and water pump with no PS, PB or AC). It has only been driven about 10-15 miles but appears to have settled a little already. Still a tad too high for my tastes but I will be waiting for 100 miles or so before I do something else. Coil springs do settle.
Jeff
Old Apr 12, 2003 | 10:05 AM
Ybnormal's Avatar
Ybnormal
Not sure about the #550 springs, but the #460 when I cut one coil off was just right on my 81 350. Here is a link to before and after pics. www.angelfire.com/al/swhite7/temp.html
YBNormal...drive a VETTE :cool:
[Modified by Ybnormal, 3:07 PM 4/12/2003]
Old Apr 12, 2003 | 08:20 PM
turtlevette's Avatar
turtlevette
St. Jude Donor '03,'11
Do what you gotta do man, i hate that off road look on a vette.
Old Apr 12, 2003 | 11:35 PM
Dax73gt's Avatar
Dax73gt
Default Re: Should I cut a coil off a #550 spring? (turtlevette)
Cutting your spring changes the rate. Here is a sight I found that helps explain by how much. http://www.allpar.com/eek/coils.html
