Differential not doing so hot
Old Apr 11, 2003 | 10:03 AM
isosceles's Avatar
isosceles
Default Differential not doing so hot
GAH! I changed my diff fluid last weekend, put the GM additive in and it solved the clunking noise. It has been whining a lot at hwy speeds and seems to be getting louder. Last night when I put the spare tire carrier back in (had spare tire lock issues) I noticed some gear oil coming from the sides and maybe the pinion seal area.
Here's my question: are the side and front bearings and seals difficult to install? I don't have my book in front of me right now, but is the front bearing pressed on the pinion shaft? How difficult is installing a rebuilt unit?
This is going to gnaw at me until I get home and crack the Haynes manual. Wish my GM books would get here! :eek:
[Modified by isosceles, 3:04 PM 4/11/2003]
Old Apr 11, 2003 | 10:57 AM
ram82fire's Avatar
ram82fire
Default Re: Differential not doing so hot (isosceles)
The front seal can be replaced without tearing down the rear , unfortunately the side seal are a horse of a different color . You will have to pull the stub axles to replace the seals . It would be good idea considering the noise problem .
geo :crazy:
Old Apr 11, 2003 | 11:06 AM
Martin72's Avatar
Martin72
FYI....my rear is apart now. I was hearing a whining noise and decided to take a look. The left side carrier bearing was starting to flake.
Catch it early and all you will need to replace is the bearings....wait too long and it will damage other parts.... :eek: :cry
Good luck.
Old Apr 11, 2003 | 01:26 PM
Stewart's74's Avatar
Stewart's74
Default Re: Differential not doing so hot (ram82fire)
Mine leaks at the pinion seal. How would you replace this with the thing in the car?
Old Apr 11, 2003 | 01:36 PM
TedH's Avatar
TedH
Default Re: Differential not doing so hot (Stewart's74)
Removal of the driveshaft is essential. Even then, considering the frame/x-member is in the way, I'd drop the rear diff completely and then replace the front yoke seal along with the other seals, bearings and races (rebuild). You'll probably find other items that need attention while you are at it (side yokes, half-shafts, bearing assemblies, etc.). They all seem to wear out about the same time (my experience).
Old Apr 11, 2003 | 01:39 PM
Martin72's Avatar
Martin72
Default Re: Differential not doing so hot (TedH)
:iagree: And all of the rubber mounting bushings....rear spring....brake....trailing arm bushings....etc....
But when it back together.... :steering:
Old Apr 11, 2003 | 07:06 PM
isosceles's Avatar
isosceles
Default Re: Differential not doing so hot (gtr1999)
Thanks guys. I'm finally home and checked my Haynes Manual. You are WAY more help than my book. It states that repairs to the differential should be done at a certified repair shop or something like that. :crazy: I guess I just need to see how much a core charge is on a rebuilt one and just figure that into whether I try to rebuild it myself. If i mess mine up it could be 375-575 + core. If I am successful, I've seen rebuild kits for about $100 that include bearings, saving me a bundle. Hmm, looks like it might be worth a shot with some coaching from CF! :smash:
To Differential not doing so hot
