Fuel sending unit woes.
Old Apr 11, 2003 | 08:34 PM
Cookwithvette's Avatar
Cookwithvette
Default Fuel sending unit woes.
At last I've tracked down the source of my gas gauge troubles... I was able to test the sender alone today and found it to be reading 219 Ohms. Well outside the 0-90 range. I've only found one company even stocking the 75-77 style sending unit, Zips sells it for $249.95.
Anyone have any experience replacing these? I really don't look forward to dropping the tank but it has to come out anyway in order to weld in a sump. (For the EFI project) Is the tank hard to get in and out? Will I need any special parts? (gaskets?) Just looking to see what I'm getting into.
Old Apr 11, 2003 | 09:39 PM
wombvette's Avatar
wombvette
Default Re: Fuel sending unit woes. (Cookwithvette)
Most corvette parts houses sell the replacements for about $85. You do not need to drop the tank, just turn the retaining ring. OH, be sure to drain the tank first, or you will get a snout full.
Old Apr 11, 2003 | 10:21 PM
Cookwithvette
Default Re: Fuel sending unit woes. (wombvette)
Nope. Unfortunately 75-77 uses a rubber bladder inside the tank. Sending unit for these years mounts through the top and clamps the top of the bladder on.
I'm definately going to check around locally. There is a Corvette parts store only about 12 miles away. I'll even check Autozone and Advance just for giggles. (They hate me, I'm sure. I'm always coming in asking for some obscure part. Maybe I'm becoming a *butt* but I'm almost starting to enjoy confusing them. :lol:)
Old Apr 12, 2003 | 01:54 AM
wombvette's Avatar
wombvette
Sorry, you are correct, I dont mess with many of those and just forgot what year it started.
Old Apr 12, 2003 | 11:18 AM
Matt Gruber's Avatar
Matt Gruber
i've always been able to fix them. it did take a couple of hours on my 67 ford; the wire was broken and just touching; read 236 ohms. soldered in a new wire and fixed a bad ground.
At least TRY to fix it; what have you got to lose?
Old Apr 12, 2003 | 11:28 AM
SanDiegoPaul's Avatar
SanDiegoPaul
From: San Diego - Deep Within The State of CONFUSION!
Check with local shops that can rebuild it. Here in SD we have a couple of places to take sending units. At work we frequently have them redone at the local speedo shop - he fixes dash circuits and tank senders as well as speedometers.
Average charge to rebuild the rheostat is about $50 and he solders on a new float too. :yesnod:
Old Apr 12, 2003 | 12:32 PM
Aaron76's Avatar
Aaron76
I remember feeling your pain. I went a whole year with out a gas gauge just because I was scared to get into it.
But when I did I found that the sender unit it in a tit pot that has two pieces to it. One was flat and the other was the part that held the reostat and the arm on the other end of the float. These two has seperated because the were built realy flimsy like a Tonka truck Knock off! so Iremoved the assy repositioned it and spotwelded it in the spots that held it togeather in the first place. Now it works great total cost one afternoon. Make sure to test it with out of the tank before instalation.
hope this helps
:cheers:
Old Apr 12, 2003 | 02:01 PM
Cookwithvette
Default Re: Fuel sending unit woes. (Aaron76)
This is very good news guys. Thanks. I hadn't thought it was repairable. Thought it burned out like a light bulb, when it dies replace it. If I can fix it on my own, or even have it rebuilt for $50 it sure beats ordering one for $300+.
Thank you all very much. :cheers:
Old Apr 12, 2003 | 07:34 PM
hunt4cleanair's Avatar
hunt4cleanair
Hey Cook:
DIY...I think that's the message here. I just wrote an article for NCRS Corvette restorer on how to rebuild your fuel gauge sending unit for pennies. It takes time, patience and an empty tank. Intereted...let me know!
Old Apr 12, 2003 | 11:20 PM
Aaron76's Avatar
Aaron76
Default Re: Fuel sending unit woes. (hunt4cleanair)
I would be interesed too
I am putting togeather a data base on corvette tech tips.
this might help
Old Apr 13, 2003 | 07:55 AM
Cookwithvette
Yes, I'd be very interested.
Thank you very much! :cheers:
To Fuel sending unit woes.
