Need a distributor recommendation
Old Apr 11, 2003 | 11:38 PM
hudman's Avatar
hudman
Default Need a distributor recommendation
I may need to upgrade my distributor. What do you guys recommend?
I need it to fit under the stock shielding.
Old Apr 12, 2003 | 01:39 AM
gearheadz's Avatar
gearheadz
Default Re: Need a distributor recommendation (hudman)
MSD Corvette Tach Drive PN 8572 .... needs an MSD ignition box though.
http://www.msdignition.com/1distche.htm
Old Apr 12, 2003 | 06:37 AM
Jvette73's Avatar
Jvette73
I upgraded my stock points dist with Pertronix Ignitor kit. It is a kit that converts the stock points dist to electronic function. Uses a stock style canister coil. The stock coil will work but I upgraded that to a 50k volt accel coil. I did have an ignitor go bad once but it was my fault for being bubba with things and messin with wires the wrong way. Other than that its been real relaible. Plus you can carry yur old points and condenser with you and slap them back in in 20mins if the ignitor ever fails.
http://www.pertronix.com you can also get these kits at summit and jegs. the IgnitorII kit is a tad over $100.
Old Apr 12, 2003 | 08:25 AM
1971454ILvette's Avatar
1971454ILvette
I sent my dist. to Dave Ray in CA. He rebuilt it and converted it to full HEI. When he rebuilds it he puts new bearings in it and gives it a general overhaul. I went this way because Petronix did not have a kit to work with my dist. Dave also puts on a new rotor and cap. He charged me $175 plus shipping to him. He paid for shipping back. He cleans it up and makes it look new. I would highly recommend him. Here is his website http://www.davessmallbodyheis.com
Jay
Old Apr 12, 2003 | 08:55 AM
914eener's Avatar
914eener
Default Re: Need a distributor recommendation (1971454ILvette)
I swear by the Davis HEI www.performancedistributors.com They are custom curved based on your cam/heads, etc. and the price is competetive with the Mallory's of the world.
Old Apr 12, 2003 | 11:25 AM
TedH's Avatar
TedH
I think Lars works on points-style distributors. Drop him a line. He worked wonders on my 1904 Q-jet carb and I'm buying his HEI recurve kit soon.
Send me a note if you want Lars' email address.
Old Apr 12, 2003 | 11:41 AM
AlwaysWave's Avatar
AlwaysWave
Cruise-In III Veteran
I'm using the Pertronix Ignitor with an MSD 6A box and coil. It's trouble free and always has been. I personally like the 20 degree spark duration the MSD 6A box gives.
I recently contacted Crane about thier new XRi ignition module. They said it is not compatable with any spark box such as the MSD. If you don't intend to use any add ons, I'd suggest the XRi because it's a bit simpler than the Pertronix.
Old Apr 12, 2003 | 01:42 PM
Rogue Wave's Avatar
Rogue Wave
CI 4-5-6-7-8 Veteran
St. Jude '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-16-'17
Default Re: Need a distributor recommendation (mdsmith)
:iagree: When I put in the new engine I went with the MSD distributor and a MSD 6A box. :thumbs:
To Need a distributor recommendation
