Exhaust Smoke
Old Apr 12, 2003 | 06:53 AM
luvmy82's Avatar
luvmy82
St. Jude Donor '12
Default Exhaust Smoke
I need your opinion on something that I noticed when I took my CE for a spin after a long winter respite.
When prepping the car for the winter, I filled up the tank and put the proper ratio of Stabil in the gas tank (I'm saying this because I'm not sure if it might have something to do with the problem).
I noticed that when I floor it, that more than the normal amount of exhaust smoke is behind me. Also, when I first start it up, it's a little smoky in the garage. The smoke does not smell like oil burning. It's just a real concentrated exhaust smell.
It is a garage queen, and I have since diluted the amount of Stabil left in the gas tank by filling it up (I drove it until I hae 1/2 tank left).
I just want to make sure that this is nothing to be concerned about.
What are your thoughts?
Old Apr 12, 2003 | 07:06 AM
Twin_Turbo's Avatar
Twin_Turbo
Default Re: Exhaust Smoke (luvmy82)
What color is the smoke and pull a couple of plugs and check them for color and deposits
Marck
Old Apr 12, 2003 | 07:15 AM
luvmy82's Avatar
luvmy82
St. Jude Donor '12
Default Re: Exhaust Smoke (Twin_Turbo)
It's white, not blue or grey
Old Apr 12, 2003 | 07:31 AM
Twin_Turbo's Avatar
Twin_Turbo
White is water, does your exhaust smell sweet?? Pull all the plugs, the one that's very clean is the cylinder that has a leak. Drain the oil, check for coolant in it (will come out first) and check the cooolant reservoir and/or rad for oil floating on the coolant.
If one of the outer cylinders has coolant in it you may have an intake gasket leak which is easy to fix, if it's one of the inner ones it's most likely a blown head gasket or a cracked head
Drain the oil though and fill it up with fresh oil and use a preluber to circulate and drain again, coolant on the bearings will eventially damage them
Marck
[Modified by Twin_Turbo, 1:30 PM 4/12/2003]
To Exhaust Smoke
