headlight vacuum canister?
Old Apr 13, 2003 | 06:03 PM
scorciae's Avatar
scorciae
Default headlight vacuum canister?
ok i read that this is supposed to store air so that i can work my headlights after the car is off, this does not work on my car, so i am wondering if i can remove it and plug the vacum lines directly into my headlights?
Old Apr 13, 2003 | 06:33 PM
goinbroke's Avatar
goinbroke
Default Re: headlight vacuum canister? (scorciae)
I don't know why that wouldn't work. Give it a shot. Are the headlight doors working OK with the engine running?
Old Apr 13, 2003 | 06:44 PM
scorciae's Avatar
scorciae
Default Re: headlight vacuum canister? (goinbroke)
"working ok" well, they do open and close they just take there time and go one at a time
Old Apr 13, 2003 | 08:28 PM
goinbroke's Avatar
goinbroke
You may need to go through the troubleshooting procedure below for slow headlights. There are several components in the system that can cause problems and any of them can be repaired or replaced without much trouble. Even the relays can be rebuilt if you don't want to buy new ones.
http://www.corvette-101.com/ Click on "Vacuum Trouble"
As for bypassing the vacuum canister.....shouldn't be a problem.
[Modified by goinbroke, 7:30 PM 4/13/2003]
Old Apr 13, 2003 | 08:46 PM
CWUin82's Avatar
CWUin82
goinbroke,
I checked out your headlight vacuum page....nice job. Thanks for sharing it.
scorcaie,
Good to see another Mainiac here!
Old Apr 13, 2003 | 09:04 PM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
Default Re: headlight vacuum canister? (CWUin82)
If it is your headlight actuators, those are the easiest to rebuild. My reservoir is to blame for my problem I think. I am gonna try the tests listed on goinbrokes page and see if it may be my control valves that are leaking down.
Old Apr 13, 2003 | 09:55 PM
mbeeman350's Avatar
mbeeman350
St. Jude Donor '03-'05-'06-'07-'09
Thanks "Goinbroke" for the web page. I have problems with my headlights and this was a great help!!!!
Mark :thumbs: :thumbs: :thumbs:
To headlight vacuum canister?
