Need Advice: Door handle/Armrest fix (interior)
Old Apr 13, 2003 | 07:45 PM
1980C3's Avatar
1980C3
Default Need Advice: Door handle/Armrest fix (interior)
Pulled on the interior door handle and the BACK of the armrest came lose, not the front (as is typical).
Looks like that the previous owner used only 1 "oversized" screw in the rear postion screw hole, and didn't put one in the middle position (just under the door lock ****). Now, the middle position hole on the metal door panel appears to be fine and still has the metal spacer frame around it, BUT the rear postion hole (in the door panel) is enlarged since an oversized screw was used to hold it in place. Needles to say, the hole is stretched, and the prior fix did not work.
I am going to order a set of stock spec. screws, and while one may work in the middle hole, the stretched out hole most likely will not thread. Is there something I can place in the hole to make it threadable again?
Old Apr 13, 2003 | 08:29 PM
red topless gator's Avatar
red topless gator
Default Re: Need Advice: Door handle/Armrest fix (1980C3)
I have oversized screws in mine also...........LT
Old Apr 13, 2003 | 08:31 PM
Paul L's Avatar
Paul L
You can use a metal or plastic drywall anchor secured in place with JB Weld.
Old Apr 13, 2003 | 09:03 PM
drs80vette's Avatar
drs80vette
JBWeld a nut behind the enlarged hole, then use the sized fastener, prefereably a machine bolt, small gauge, not too long. The expoxy should hold the nut in place long enough to establish torque to make er tight.
Old Apr 14, 2003 | 09:13 AM
1980C3's Avatar
1980C3
Default Re: Need Advice: Door handle/Armrest fix (drs80vette)
Sounds good.
Has anyone tried this product? http://lawn-and-garden.aubuchonhardw...kit-701351.asp
Might work, and I would not have to remove the door panel.
Old Apr 14, 2003 | 10:42 AM
gliot1's Avatar
gliot1
St. Jude Donor '12-'13
Mine are the same way. The remedy I used is "U" or "J" nuts. These are the sheetmetal bent over type of nuts that are used on cars all over the place. Most local hardware stores have very large ones, with machine thread or sheet metal thread. Just slide them around the sheet metal and align the holes. You can tighten the screws as hard as you can with no problem. I wasn't worried about orginality, as I don't know of shows that make you pull door panels. :smash: :smash: :hurray:
Old Apr 14, 2003 | 10:55 AM
UKPaul's Avatar
UKPaul
Default Re: Need Advice: Door handle/Armrest fix (gliot1)
:iagree: Very useful fastners to have when you own a Vette :)
:cheers:
To Need Advice: Door handle/Armrest fix (interior)
