Engine Fire...
Old Apr 13, 2003 | 09:53 PM
thomar2k1's Avatar
thomar2k1
Default Engine Fire...
Hey all, just pulled the '74 out for the first good run of the season, and I had a massive carburetor backfire that killed the motor, and flamed until I was able to hit it with the fire extinguisher. Worst bit is, I took it to a Vette specialist for serious engine work over the winter.
That said... anyone able to tell me what may have caused this? The carb is a Holley, and was idling at 1000RPM in Park/Neutral, and at 700RPM under load. I'm at a loss... and hoping the insurance company is going to come through.
:mad
Old Apr 13, 2003 | 09:54 PM
LFZ's Avatar
LFZ
Default Re: Engine Fire... (thomar2k1)
ouch :eek:
Old Apr 13, 2003 | 10:58 PM
joeveto's Avatar
joeveto
Cruise-In IV Veteran
Cruise-In V Veteran
St. Jude Contributor
Sorry to hear that.
:U
Old Apr 13, 2003 | 11:04 PM
gdh's Avatar
gdh
If you don't keep the maintenance up on Holley's they are notorious for leaking fuel. I am taking mine apart this week as it is leaking after sitting over the winter.
Old Apr 14, 2003 | 01:52 AM
Desertdawg's Avatar
Desertdawg
St. Jude Donor '09
Default Re: Engine Fire... (gdh)
How bad did it burn????
Sorry to hear this. And welcome to the Forum :cheers:
Old Apr 14, 2003 | 05:21 AM
GaryS's Avatar
GaryS
Like the others, I am sorry to hear that you had problems. At least you had a fire extinguisher. I wonder how many board members are driving around with 20 or 30 year old cars without fire extinguishers. :eek: Once of the cheapest insurance policies out there.
Gary
Old Apr 14, 2003 | 07:15 AM
Matt Gruber's Avatar
Matt Gruber
was the air cleaner on before the fire?
did you try to restart it?
Old Apr 14, 2003 | 08:06 AM
gdh's Avatar
gdh
Default Re: Engine Fire... (Matt Gruber)
Right after I started my new engine last summer it had a tremendous backfire and it started a fire. Glad my mechanic was with me as he calmly told me to re-start and the fire was sucked right back into the carb.
Old Apr 14, 2003 | 08:58 AM
Avette4me's Avatar
Avette4me
Cruise-In VIII Veteran
:seeya Don't have the backfire answer as a backfire can be caused by several things - timing, lean, etc. just wanted to say welcome to the forum.
Old Apr 14, 2003 | 09:00 AM
Alwyn678's Avatar
Alwyn678
Default Re: Engine Fire... (Avette4me)
Ouch how much damage did it do.........Any fiberglass melting??
Old Apr 14, 2003 | 04:19 PM
rainman69's Avatar
rainman69
Every once in a while, if I let go of the key at just the right time during the start, I'll get a carb backfire. The nice thing is, they're very distinct sounding, and fairly simple to cure...crank the motor again and suck the flames down in the intake.
But, worry is why I always have a fire extinguisher handy, and recommend the VetteDan kit to anyone and everyone.
Old Apr 14, 2003 | 06:20 PM
Desertdawg's Avatar
Desertdawg
St. Jude Donor '09
Default Re: Engine Fire... (rainman69)
Do you have a link :confused: :seeya
Old Apr 14, 2003 | 07:45 PM
thomar2k1's Avatar
thomar2k1
Default Re: Engine Fire... (Desertdawg)
Fortunately... the hood was up and air cleaner was off trying to find the cause of the backfiring in the first place. So it looks like the only damage is the chemicals in the carb and all over the rest of the surfaces in the engine. The insurance company looks like they are going to come through (woo hoo State Farm).
Wish I would have known that trying a restart could put the fire out... but I guess this is one of those things that I am going to learn from... unfortunately it's at the cost of not being able to drive it for about a month in the short Michigan driving season.
Thanks to all for the support! :)
Old Apr 15, 2003 | 02:13 PM
Matt Gruber
i've learned :cuss to keep the air cleaner on whenever starting. a fire will tend to go out from lack of oxygen as it can't draw air thru a paper filter. gives me time to restart to be sure it is out.(don't take the lid off and look :nopity
those new paper filter lids may prove to be very exciting now and then :D
Old Apr 15, 2003 | 04:11 PM
vettedan's Avatar
vettedan
Desertdawg-Go to http://www.vetteworksonline.com for C3 extinguisher brackets and a full assortment of Amerex fire extinguishers.
Dan :cheers:
To Engine Fire...
