"H" PIPE EXHAUST SYSTEMS????????
Old Apr 14, 2003 | 01:27 PM
GRAYGHOST's Avatar
GRAYGHOST
Default "H" PIPE EXHAUST SYSTEMS????????
I've noticed that in the desciptions of many of your cars, there is something
called an "H" pipe. I've figured out what they look like from some of the
adds in the various magazines I subscribe to but I would really like to know
what exactly they do for performance? Educate me , please.
[Modified by GRAYGHOST, 6:28 PM 4/14/2003]
Old Apr 14, 2003 | 01:46 PM
norvalwilhelm's Avatar
norvalwilhelm
Default Re: "H" PIPE EXHAUST SYSTEMS???????? (GRAYGHOST)
The H pipe helps increase torque, cuts down some of the drooning in the exhuast and make both sides of the exhaust available to the other side.
This is a shot of my H pipe.
Old Apr 14, 2003 | 03:47 PM
GRAYGHOST's Avatar
GRAYGHOST
Default Re: "H" PIPE EXHAUST SYSTEMS???????? (norvalwilhelm)
Great picture! Thanks a lot for the enlightenment!
Old Apr 14, 2003 | 04:26 PM
Aaron-74's Avatar
Aaron-74
Here's mine. It's welded right after the cross-member.
Old Apr 14, 2003 | 04:39 PM
mvftw's Avatar
mvftw
Are there H-Pipe kits, I've only found duals, if no H-pipe. My local shop wants $750 for duals & H-pipe, a little pricy for me...
Old Apr 14, 2003 | 04:40 PM
Alwyn678's Avatar
Alwyn678
Default Re: "H" PIPE EXHAUST SYSTEMS???????? (mvftw)
Damn I gt mine done for 175 :eek:
Old Apr 14, 2003 | 04:43 PM
Aaron-74's Avatar
Aaron-74
Default Re: "H" PIPE EXHAUST SYSTEMS???????? (Alwyn678)
I got 2.5 aluminized pipes with an H-pipe fully welded and sealed (no tips, just down turned) for 300.00$ Tips were another 50.00$ which I plan to get soon..700.00$ and it better be mandrel bent and fully custom. :bs
Old Apr 14, 2003 | 05:00 PM
mvftw's Avatar
mvftw
Default Re: "H" PIPE EXHAUST SYSTEMS???????? (Aaron-74)
That's why I asked, I'm going to get the Mid-America kit for $300 (duals - no H), but I'm going to look around for better pricing first...
Old Apr 14, 2003 | 05:53 PM
79VetteMike's Avatar
79VetteMike
That is a rip off. Find someone else to do it.
Old Apr 14, 2003 | 05:55 PM
79VetteMike
I have the Mid America 2.5" dual set up on my 1979 that I am willing to sell and it has the H pipe installed from a local shop. Oh yeah, it is fully welded with Flowmasters 40 series. I did cut it to drop my rear diff though.
Old Apr 14, 2003 | 08:09 PM
vettfixr's Avatar
vettfixr
The H pipe typically improves low end torque and quiets the system a bit. Here are a few pics of my setup with Dynomax headers.
[Modified by vettfixr, 8:09 PM 4/14/2003]
Old Apr 14, 2003 | 08:32 PM
DaddyO's Avatar
DaddyO
Default Re: "H" PIPE EXHAUST SYSTEMS???????? (79VetteMike)
How much are you looking to sell that for? Will it work on a stock 71? Easy to install?
Email me at: dan.fulop@gs.com
Old Apr 15, 2003 | 08:14 AM
Ganey's Avatar
Ganey
called an "H" pipe. ...
Also called a balance pipe. Rec.!
Old Apr 15, 2003 | 09:29 AM
Twin_Turbo's Avatar
Twin_Turbo
Default Re: "H" PIPE EXHAUST SYSTEMS???????? (Ganey)
Rec.!
Why? All it does for certain is mellow out the exhaust note. I haven't seen dyno proof that a balance pipe makes more power. I like my exhaust loud, don't have a balance pipe. Furthermore, just putting in a bal;ance pipe won't do anything, you have to position it at a point where there's a "knot" in the longitudinal wave.
Old Apr 15, 2003 | 01:24 PM
SCS Red80's Avatar
SCS Red80
St. Jude Donor '10, '13
Default Re: "H" PIPE EXHAUST SYSTEMS???????? (vettfixr)
Man it seems the more I read on this whole topic the more confused I get. I have an 80 that I want to get duals on and get rid of the converter. I was going to just have the pipes run straight back from the original headers (for now) to Flowmaster 50's and then tips out the back. Will this work? Will there be clearance issues if the pipes run under (closer to the ground) the crossmember, or should I set it up like the MAD systems and run both pipes down the pass side? And now - what about an H pipe? Do I need one, and if so where would it go?
Steve*
:flag
Old Apr 15, 2003 | 01:44 PM
79VetteMike
Default Re: "H" PIPE EXHAUST SYSTEMS???????? (SCS Red80)
Steve*
:flag
Is there one or two holes in your crossmember? If it has 2, I am moving to OKC in mid-June, and I would sell you my set up if you are interested. It's a Mid America kit with Flowmasters on it-sounds really nice-also has the H pipe.
Old Apr 16, 2003 | 12:38 AM
SCS Red80's Avatar
SCS Red80
Mike,
Looks like no holes, just an indentation where the cat meets the front "Y" and then the rear "Y" takes off from the Cat to the exhaust.
Thanks for the offer, but I want to get this done soon, like next week - found a guy in town that will do all the pipes and the Flowmasters for $400.
BTW - you an AWO?
Steve
:flag
To "H" PIPE EXHAUST SYSTEMS????????
Old Apr 16, 2003 | 07:42 AM
79VetteMike
That sounds like a decent deal. No, I'm not an AWO-I'm a 2M tech. I am assuming you are an AWO?
Old Apr 16, 2003 | 07:44 AM
79VetteMike
Default Re: "H" PIPE EXHAUST SYSTEMS???????? (DaddyO)
I don't think it will fit your car. It lists a different set in Mid America.
Old Apr 16, 2003 | 12:52 PM
SCS Red80's Avatar
SCS Red80
Yea your right, i just looked at the MAD web site and up to the 79 it looks like two holes available in the cross member, and mine is just a indentation around the center. Oh well like you said Im getting a pretty good deal.
No Im not a AWO, a WD - whats a 2M tech?
Steve
:flag
