Collector Gasket Again!!!
Old Apr 14, 2003 | 03:47 PM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
Default Collector Gasket Again!!!
I know this is the caveat of headers but only after about 250 miles. What can I do to make these stay put?
Old Apr 14, 2003 | 03:54 PM
Alwyn678's Avatar
Alwyn678
Default Re: Collector Gasket Again!!! (Eddie 70)
copper or aluminum gaskets
Old Apr 14, 2003 | 03:58 PM
SanDiegoPaul's Avatar
SanDiegoPaul
From: San Diego - Deep Within The State of CONFUSION!
Default Re: Collector Gasket Again!!! (Alwyn678)
:iagree:
I installed copper gaskets on my car and never regretted it!
Old Apr 14, 2003 | 03:59 PM
burners's Avatar
burners
Cruise-In IV Veteran
Cruise-In V Veteran
Make sure the surfaces are true. Use a file to get them flat and clean. Use some copper RTV for exhaust systems on both sides of the gasket. Don't goop it on. A thin layer is enough. I always used the metal impregnated gaskets because they lasted a lot longer. I have since switched to Percy's aluminum collector gaskets, they are much better. If you need to you can double the gaskets but use RTV between them.
Old Apr 14, 2003 | 04:01 PM
norvalwilhelm's Avatar
norvalwilhelm
I have had good luck with normal cheap collector gaskets and black RTV. The same stuff I use on the ends of the intake manifold.
Old Apr 14, 2003 | 04:04 PM
PatsLs1vette's Avatar
PatsLs1vette
Default Re: Collector Gasket Again!!! (norvalwilhelm)
i switched to flowtechs aluminum ones ,they wrok great.
Old Apr 14, 2003 | 04:48 PM
Edzred72's Avatar
Edzred72
HA!! Yours lasted longer than mine!! Then I went out and got Percy's soft aluminum.....suggest the same for you.
Eddie :cheers: :cheers:
Old Apr 14, 2003 | 04:52 PM
TedH's Avatar
TedH
:iagree:
Old Apr 14, 2003 | 05:00 PM
timbo79's Avatar
timbo79
Default Re: Collector Gasket Again!!! (TedH)
Copper RTV works.. I had the same problem.... I will soon be switching to Sanderson's as they have thicker flanges and I won't constantly be tightening them down at the heads. Will also give me about 2 extra inches of ground clearance..
Good Luck :cool:
Old Apr 14, 2003 | 07:41 PM
73 LS-4's Avatar
73 LS-4
I've tried about everything on mine, I even warped a set of Soft aluminum ones so the 3" hole looked like an egg when I pulled it out, weired. I just use cheapies and replace them all the time now, now can do both collectors in under 5 minutes. One of these days I'll figure out what's going on there.
:cheers:
Pat Kunz
Old Apr 14, 2003 | 07:44 PM
vettfixr's Avatar
vettfixr
I'm using a set of copper gaskets from Summit and they've held up well.
Old Apr 14, 2003 | 09:13 PM
Eddie 70's Avatar
Eddie 70
Default Re: Collector Gasket Again!!! (timbo79)
I called this afternoon and got me some copper gaskets from the header manufacturer. These better last. They cost like gold. :eek:
Old Apr 14, 2003 | 10:21 PM
Perfomer's Avatar
Perfomer
Go to your local Advance Auto and get the aluminum ones for about 12.00 bucks the work great.
To Collector Gasket Again!!!
