Cheap replacement for radiator/rad. support foam seal
Old Apr 15, 2003 | 04:50 PM
tshort's Avatar
tshort
CI 7-8 Veteran
Default Cheap replacement for radiator/rad. support foam seal
Have any of you guys found a place that sells the black foam that you can replace the old foam seals that go between the radiator and the radiator support? I've tried Auto Zone, Pep Boys, and Home Depot with no luck. My current foam is dry rotted and falling apart.
Old Apr 15, 2003 | 05:18 PM
burners's Avatar
burners
Cruise-In IV Veteran
Cruise-In V Veteran
Default Re: Cheap replacement for radiator/rad. support foam seal (tshort)
I found some dark gray foam at Wal-Mart. It's for air conditioners and ductwork. It's 2"x2" and about 5 feet long. You will need two to cover the entire circumference of the opening.
Old Apr 15, 2003 | 05:20 PM
Metal Wulf's Avatar
Metal Wulf
Default Re: Cheap replacement for radiator/rad. support foam seal (burners)
When I replaced my rad, I got the foam from Zip :thumbs:
Old Apr 15, 2003 | 05:21 PM
Frankenvette's Avatar
Frankenvette
I use pipe wrap from Home Depot. Cheap and easy to install/uninstall as needed. I have not used anything but this since owning the car with no problems.
Old Apr 15, 2003 | 07:19 PM
72GACRZR's Avatar
72GACRZR
I had a 6 inch gap on the passenger side and cut a dark grey piece out of a computer box packing foam, OPPS, I think I just confessed to a Bubba fix. :lol:
Old Apr 15, 2003 | 07:55 PM
tshort's Avatar
tshort
CI 7-8 Veteran
That sounds like the ticket. Thanks guys, I'll try Wal-Mart.
:crazy: Geesh, talk about Bubba :lol:
Old Apr 15, 2003 | 08:07 PM
Wrecked82's Avatar
Wrecked82
My only problem with that stuff, if it is what I think it is, is that it is not dense enough. Too much open cell. Needs to have some body to it.
The pipe wrap stuff works well on the bottom and sides.
Also needs to have some compressability to it, so the computer packing stuff might or might not be the ticket, depends on the material.
Old Apr 15, 2003 | 08:36 PM
PRNDL's Avatar
PRNDL
I used the black, soft, pipe insulation from Home Depot. You can buy it either "plain" or with an adhesive edge (covered with blue tape that you peel off). The adhesive edge can come in handy, but you should probably use weatherstrip adhesive also. The grey stuff I am thinking of is too light, a little stiff, and could shrivel up if exposed to high enuf temperatures.
Old Apr 15, 2003 | 09:39 PM
phoenix's Avatar
phoenix
Default Re: (MNJack)
Go to Mcmaster.com and do a search for foam rubber insulation. You can buy strips of any length and thickness with variable density, deformity and tensile strength. They also sell chemical resistant, heat resistant and flame retardant versions.
It's all reasonably priced too. I feel a lot more comfortable using this stuff when I know what temperature it is rated for. :D :cheers:
To Cheap replacement for radiator/rad. support foam seal
