Rookie Needs advice
Old Apr 15, 2003 | 07:18 PM
Vtoys's Avatar
Vtoys
Cruising
Default Rookie Needs advice
Late last year I lost a race with a deer. I have a headlight support on order and will replace it next week. Will this support come out the lid hole? Do I need to remove the vaccuum assembly while the support is in the car or will the support come out with the vaccuum module installed? Or am I screwed and I have to remove the front bumber to replace the support? Thanks for yer help. Patrick forever@hills.net
Old Apr 15, 2003 | 09:58 PM
78Vette-SA's Avatar
78Vette-SA
Default Re: Rookie Needs advice (Vtoys)
Sorry can't help you but just wanted to say hello and welcome. I'm sure someone will chime in.
:steering:
Old Apr 16, 2003 | 12:34 AM
joeveto's Avatar
joeveto
Cruise-In IV Veteran
Cruise-In V Veteran
St. Jude Contributor
Patrick, welcome.
I'm not sure about this one. But I'll give it a shot. I think you can do it all through the headlight hole and the front grill opening. It's been two years since I've messed with mine. And I believe this is all that is necessary.
I'm sure someone who actually knows, will chime in soon.
:cheers:
Old Apr 16, 2003 | 03:18 AM
Desertdawg's Avatar
Desertdawg
St. Jude Donor '09
Default Re: Rookie Needs advice (joeveto)
:cheers:
That's not me, But welcome to the mad house :cheers: :seeya
Old Apr 16, 2003 | 03:26 PM
72GACRZR's Avatar
72GACRZR
Welcome :seeya
I have not done it, but there are several threads in the archives, here's one
http://forums.corvetteforum.com/zerothread?id=207072
To see the others, do a search for headlight assembly in C3 section and archives.
I remeber one of the magazines did an artical on this and said it can be done, but you have to take it apart.
Hope it helps
To Rookie Needs advice
